What did you use to take the hose the screw under the egr valve?if im putting the 93 cobra intake on will i need to reuse it?
VibrantRedGT said:You don't have to disconnect the fuel lines from the rail. Just move it out of the way. Lay the new intake down then put the rails on. Quicker, easier and less mess.
95mustang_gt said:here is where i found the info about the coolant line
http://forums.stangnet.com/showthread.php?t=578261&highlight=fuel+line+disconnect
95mustang_gt said:alright thanks,Well now im going to be putting the lower intake on.I have a question about the oring and diamond shape gasket that comes with the felpro set.What are those for?
95mustang_gt said:here is where im stuck i have to hose one green and one red and then i have the vapor canister hose.Does the vapir canister hose plug into the vacuum tree?
