In The Middle Of Fuel Pump Install, need some help!!!
you wanna undo the one with the big lock-ring around the perimeter...thats where the pump is located..
shoot that ring with some WD or PB...take a drift pin and tap it out...tapping cross-sides on the tabs that are sticking up....once that rings out....vacuum the top off before pulling the cover....weasel the pump/sending unit out...
BlueOvalStangGT said:
ACKK I LIED, got everything in, but i cant get the assembly in right? is there a specail way this thing slides in?? heeeeeeeeeeelllllllppppp
Yes, it's called remember how you take it out. It must go into the baffle. Just work with it and don't forget to use a new o-ring.
