Hey guys!
I want to try and clear up a little confusion here. We offer two different coilover solutions for the early Mustangs. The
'Bolt On' coilover will work with the factory or TCP upper control arm and mounts in the factory shock location. It maintains the stock motion ratio but gives you the added benefit of less bind, your choice of ride height range and variable spring rates.
Our
TCP FCOC-FD kit is a full coilover conversion system. This kit is more similar to the Global West system mentioned above in that the shock mounts to the lower control arm. It includes the upper and lower control arms, our TrueCenter Pivot Socket adjustable strut rods (the only ones on the market that maintains the correct geometry) and a pair of Varishock coilovers. We engineered and manufacture this shock exclusively for this system; it's not adapted from a universal application shock. In addition to improved center of gravity and motion ratio, this kit also adds a bunch of adjustability and rigidity that helps the car handle the way it should.
All of these components are made here in our Sacramento, California factory and will work with the factory V8 spindle and with either stock or aftermarket steering systems. I would be happy to answer any further questions anyone may have. My extension is 247 or you can email me:
[email protected]
To see more details on all our front suspension kits, download instructions or data sheets (which are full of information) click
HERE.
