injector issues....91 GT
  • Thread starter Thread starter m109ted
  • Start date Start date Dec 21, 2009
M
m109ted
Piedmont SD
Dec 21, 2009
  • Dec 21, 2009
I recently got a 91 GT in MO and drove it up to SD. It ran great. 2 days later,6 of the 8 injectors were leaking gas. I got new 19# from Summit and got the old,cracked,mismatched ones replaced. I put it back together and took it for a test drive. It felt like it was mifiring or it was intermittant on 1 cylinder. It didnt feel like full power either. I took it apart 3 more times to check all wiring and replace gaskets on the plenum and throttle body. Now it seems to be worse!!! Is there a way to test injectors without dismantling everything?? What else might it be?? Thanks guys.
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Dec 21, 2009
  • Dec 21, 2009
Use an ohm meter and test the resistance across the terminals of the injector. Should see 12-16 ohms.
Next use a test light and place it across the injectors electrical plug terminals. Make sure its flashing while the engine is running.
M
m109ted
Piedmont SD
Dec 21, 2009
  • Dec 21, 2009
but what about the plenum? Doesnt it have to be on? Its in the way!!!
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Dec 21, 2009
  • Dec 21, 2009
When using the test light. If you can reach under the manifold, and unplug the injector. Then hook the test light to it to check for injector pulse. Do the passenger side first. You might find something there and not need to worry about the driverside.
If you know how to pull codes, then you could do a cylinder balance test, and that may point you to an injector or cylinder to focus on.
How are the ignition components?
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
L
Engine Need help diagnosing 2 dead cylinders
  • lvgnmz
  • Feb 13, 2025
Fox 5.0 Mustang Tech Feb 13, 2025
Mustang5L5
  • Gulftown980x
  • Jul 29, 2026
squeak93
2001 SVT Cobra Overheating Issue
  • bradencaron0
  • May 8, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 8, 2025
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
