injector question
Yes, the noid light tells you if you are getting power and ground to the injector, but not what is going on with the actual fuel delivery. There is key-on voltage to the injector that is constant; the computer controls the ground signal to the injector to control pulsewidth.
A cylinder balance test is about the best test I can think of to measure the injector flow with the injectors in the car.
Good luck.
BlkSn is right on. If one hunts around, the cost to have injectors cleaned and flow tested can be quite reasonable.
Good luck.
Don't Laugh :nono:
I remember reading about some guy rig up a way to supply fuel and 12 volts to run them 10 seconds in a clear test container.
He then compared the spray pattern, and the amount of fuel in his test container for all eight inj's.
Now that I think about it, if you ran the test with oem pressure, I guess you could multiply the amount of fuel in the tank by 6 and it should be close the the inj's rating :shrug:
Grady
