Injector question
LaserSVT
3,548
233
When I get my KB 2.1 twin screw will I need to get bigger injectors with 6 lbs of boost or be safe and get bigger ones? I figure if so I would do it at the same time so when I get the KB chip with the blower I can have it programmed for the same size injectors. Also how much HP can the stock MAF handle before it pegs?:shrug:
Thanks one and all!
The 96-98 Cobra kit does not come with injectors, only a boost-a-pump. I figured on getting a Lightning MAF at the same time, since I will get the two tune chip I can have it programmed for the Lightning MAF and injector size. I figured to save money now if I could use the stock injectors and down the road when I change the pully then I will get bigger injectors. Anyone know how much boost a stock block can take with a good tune?
I would not chance the stock injectors,save money now, risk detonation/lean condition, pay much,much more later. you can find 03-04 cobra take outs pretty cheap.
I was thinking the same thing, arnt Terminator injectors 42lbs?
Will that support me to 9psi on the blower?
I think they are 39's. the 9 psi KB kit comes with 36's(some are 38's). I have the 38's and work well
I think what I will do is just get the 6lb kit with the chip for 3800, and after I get bored with it I will get the 9lb pulley with the larger MAF meter, 42lb injectors, a large fuel pump (not sure which one) and send the chip to KB for a reprogram.
blkhorse, did you start with the smaller kit? If so how much hp were you putting out, and how much do you have now?
I went with the 9 psi intercooled kit,have not had it on a dyno, but it Rocks!!!
KB says they dont make an intercooled system for the 96-98 Cobra:shrug: Must be the red head bastard stepchild:mad:
The tech told me he does not recommend going above 7-8 psi on their system and the setup is just right at 6 psi so that I dont need larger injectors, which makes me ask what size are the stock Cobra injectors? I want 400 rwhp and I want a twin screw b/c of bottom end torque. Does anyone else make a screw for tyhe Cobra? I cant afford alot ($4000 max) so twin turbo is out and I just like the KB. I guess down the road when I do a rebuild I can lower the compression and put a smaller pully and get more boost. It just seems with what I have and if I get the 8 lb pully and larger pump and injectors I should be right @ 400 rwhp.
