Injector sizing ????????
  • Thread starter Thread starter RYC CUKR
  • Start date Start date Mar 3, 2007
RYC CUKR
1,437
Orlando
Mar 3, 2007
  • Mar 3, 2007
I have a spare engine and the one in my 88 is starting to get a little old so before it completely croaks I am planning on building a 331 NA motor with a set of ported twisted wedge heads, custom cam and moving the intake mods from 93 over to my 88. My question is what size injectors will I need to run cause I don't think that the stock 19s are gonna cut it anymore?
I want to get all of my parts in advance so I can just swap it all out and get it back on the road when the time comes.
C
canesstangnitro
109
Metairie, LA
Mar 3, 2007
  • Mar 3, 2007
I would use the 30 # injectors with the setup you have. I like to always build my setup to use 42 # injectors because you get a lot more flow with those. I am a ford parts guy so I would get the ford racing 30 # injectors
304billet
315
  • Mar 5, 2007
30's
Mustang5L5
Mod Dude
Feb 18, 2001
43,378
18,123
224
Massachusetts
Mar 5, 2007
  • Mar 5, 2007
If leaving N/A....30's
Grn92LX
Fidanza Man!
6,819
64
129
New York
Mar 5, 2007
  • Mar 5, 2007
36's at least. I have 30's and they're near maxed out up top on my n/a TW headed 347. I'd step it up on the manifold too. TFS R, holley or a victor efi.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 5, 2007
  • Mar 5, 2007
Injector HP ratings: divide flow rating by.5 and multiply the result by the number of injectors. This uses a 100% duty cycle. These ratings are for naturally aspirated engines.
Example:
19/.5 = 38, 38 x 8 = 304 HP
24/.5 = 48, 48 x 8 = 384 HP
30/.5 = 60, 60 x 8 = 480 HP
The preferred duty cycle is about 85% maximum, so for a safety factor multiply the final figure times .85.
304 HP x .85 = 258 HP
385 HP x .85 = 326 HP
480 HP x .85 = 408 HP
Remember that the above ratings are at 39 PSI. Increasing the pressure will effectively increase the flow rating. Example: a 19 lb injector will flow 24 lbs at 63 PSI, and a 24 lb injector will flow 30 lbs at 63 PSI.
See http://users.erols.com/srweiss/ to get the calculators used in these examples.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Mar 5, 2007
  • Mar 5, 2007
30's no doubt!
If you want more injector, you would like a tune. Fortunately for you, you won't need any more...good luck! Nice combo!
Grn92LX
Fidanza Man!
6,819
64
129
New York
Mar 5, 2007
  • Mar 5, 2007
Just try and listen to those with experience with similar stuff. My 30's are near maxed out and you have better flowing heads. 36's are the ticket.
If you need more help/personal experience, PM me.
Electrical 88 EEC Injectors batch firing ?
  • Dustin 86GT
  • Dec 8, 2025
Fox 5.0 Mustang Tech Jan 8, 2026
gkomo
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Pro-M 75MM Bullet Flow Sheet - Is this calibrated for 36 # injectors?
  • dan50
  • Jan 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jan 11, 2026
dan50
Fuel SN95.0 fuel system
  • RedFury5.0
  • Apr 22, 2025
Fox 5.0 Mustang Tech Apr 22, 2025
AeroCoupe
