  • 1994 - 1995 Specific Tech
Injector stuck open, which one
  • Thread starter Thread starter miller92063
  • Start date Start date May 6, 2007
M
miller92063
253
Nebraska
May 6, 2007
  • May 6, 2007
How do I figure out which injector is stuck open.
Also my car is getting about 8-11 MPG(Guess)
It also seems to have a misfire and lacks power down low.
Would the injector be the cause of this?
reddy351
560
12
38
Columbus, Ohio
May 6, 2007
  • May 6, 2007
Maybe pull the plug on each injector, while the engine is running? The one that doesn't make a change in the way the engine idles is the culprit. Just a guess.
C
cbarr300
746
goose creek, SC
May 6, 2007
  • May 6, 2007
cylinder balance test
or you could do as reddy said
HISSIN50
34
129
May 7, 2007
  • May 7, 2007
The CBT is the best thing you can do (way way more accurate than listening for a difference when a cylinder is disabled).
Otherwise, you'll have to pull injectors. Make a rig that connects your air compressor line to an injector. Set the regulator to 40 PSIG. Place the tip of the injector in a clear plastic cup with water and a couple drops of soap in the water. Turn on the regulator and see if your injector makes bubbles. If it does, it's leaking.
Good luck.
C
cbarr300
746
goose creek, SC
May 7, 2007
  • May 7, 2007
good info JT...
and, you can do a cylinder balance test for free and MUCH less work.
go-stang5.0
2,244
Glenview,Il
May 7, 2007
  • May 7, 2007
Lots of times yuo can just put a screwdriver up against the body of the injector and feel the injector pulses via the screwdriver when the car is running. Find the one that isnt pulsating or pulsating less than the others and there you go. This doesn't work on all styles of injectors as some will give very little vibration to you where as others will give a lot. I haven't tried it on our cars so i couldent tell you if it works or not. But it only takes like 10 sec. to find out....
Also you could try some fuel injector cleaner...worth a shot.
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Wednesday at 1:55 PM
skidad
R
Misfire at high rpm! Help
  • Ryanm2018gt
  • Jan 2, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Jan 17, 2026
highplace11
H
M
Misfire
  • Mike3
  • May 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Mike3
M
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
