INJECTORS /MAF?
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
yall can read my signature to see what combo i currently have but i want to add i have a 255lph pump also, i want and need to upgrade my injectors fuel rails and possibly my MAF sensor and i know i need to adjust my timing is there anyone out there that can give me some advice on what i need? and do i need to change my fuel supply/ return lines? i have and and im fixing to install a holly system max 2 upper and lower intake if that matters. and what items do i need to properly tune my car for the most power. do i know it all needs to work in harmony i just want to know what its gonna take and how to give my car a proper tune but i dont have te experience in that so i am asking.
i got the pump with it but the kit was an ebay special and i didnt get the injectors or the mass airflow sensor. im gonna have to buy all that seperate, and im planning on doing that soon thats why im asking now.
I imagine you're looking for enough injector to adequatly supply your current combo and give you a little room to grow a the same time. That in mind....
75mm Thrttle body
75mm or larger mass air meter (PMAS or SCT for your app)
42lb injectors
Custom Dyno tune --or-- Wideband 02 and programmable tuner
The rest of your fuel system is fine for what you have there. Skip the tuning at your own peril (you'll be back in here with a new thread about your blown motor)
In your case, I would suggest the Dyno-tune. It will run you about $600 initially and about $100 for subsequent tuning if you change something.
I would call procharger and get there recomendations for injector size, and for the mass air that fits their kit, as far as fuel rails go stock should be fine for your set up you will need an adjustable fuel presure regulator. when done find a local shop with a dyno and have them tune it to get the most out of it
I would say upgrade to 30lb injectors with matching injectors, adjustable fuel pressure regulator,fuel pressure gauge, and a wideband if you can swing it. Your stock rails will be fine at your power level, unless you just want the bling bling. PM if you need a set of 30s with matching meter.
I would NOT install the minimum recommended size of injector. What gear head can leave well enough alone? Buy the things one time and leave room for further motor mods. You'll end up saving a fortune in the long run.
i kinda figured that was coming, i dont exactly have the greatest accesability to a dyno. the closest one is 4 hours away that i have found. i was just trying to make it more convenient and im gussing anyone with a dyno will be able to set my timing or make the proper changes to my computer to get the best performance out of it right? the timing and computer are my main concerns as i know very little about setting them. i can get all the parts recomended above does anybody know where i can find a dyno around the tallahassee FL area? or if they can make the changes i need?
Your setup is very mild and can be tuned with fuel pressure and timing. Now if you want every last hp out of it, then go for the tune. Start out with 10* timing with the spout out and 39lbs of fuel pressure with the vac line off. Just make sure you purchase a boost referenced capable regulator. When the boost hits, it will raise the fuel pressure as the boost rises. You may want to snoop around Turbomustangs.com , as they have a wealth of info on boosted engines.
thanks for that info as i was told by someone who obviously doesnt know what he is talking about that i didnt need to adjust my fuel pressure and where can i get a pressure regulator that is boost compatible? would a good dyno shop be able to set all of this for me?
This should help you get started. Call the ones that are nearest you.
Note: Some listings may be duplicates since the list is combined form multiple sources.
Brett's Vettes
10791 NW 53rd St.
Sunrise, FL 954-749-2836
Show Map
Dyno Performance Engineering
9205 S.W. Kansas Ave.
Stuart, FL 561-283-3482
Show Map
Dynotek
7380 N.W. 54th St.
Miami, FL 305-884-4111
Show Map
Lethal Injection Racing
1736 Unice Ave.
Lehigh, FL 941-694-0925
Show Map
Massari - Muller Racing
1984 Sherwood St.
Clearwater, FL 813-282-3255
Show Map
Perf. Dynamometer Svcs.
2427 Guava Dr.
Edgewater, FL 904-427-0390
Show Map
Pro Source Performance
5525 N.W. 84th Ave.
Miami, FL 305-591-7788
Show Map
Rare Auto Design
2220 N. Orange Ave.
Orlando, FL (407) 493-4263
Show Map
Renntech
1369 North Killian Dr.
Lake Park, FL 561-845-7888
Show Map
Rieth Motorsports
617 Industrial Ave.
Boynton Beach, FL 561-369-1711
Show Map
South Florida Performance
10718 SW 188th St.
Miami, FL 305-233-8520
Show Map
Spec R Tuning
14513 N. Nebraska Ave.
Tampa, FL 813-910-7235
Show Map
Steeda
1351 NW Steeda Way
Pompano Beach, FL 954-960-0732
Show Map
Street Rods & Classics
1552 NW First Ave.
Boca Raton, FL 561-394-4359
Show Map
The Dyno Shop, Inc.
17305 Pine Ridge Rd. #10
Ft. Myers Beach, FL 941-437-1420
Show Map
Tune Tech Auto Diagnostics
39082 US Hwy 19 North
Tarpon Springs, FL 727-939-8467
Show Map
Twilight Performance
AWD Dyno Services
527A Burlington St
Miami, FL (305) 769-0140
Show Map
Unlimited Performance
145B S. Congress Ave.
Del Ray Beach, FL 561-279-0179
Show Map
Vinci High Performance
3915 El Rey Rd.
Orlando, FL 407-292-4500
Show Map
Atlanta Chassis Dyno
1855 Buford Highway
Duluth, GA 770-623-9789
Show Map
Dynolab Inc.
1535D Rosewood Circle
Marietta, GA (678) 560-0692
Show Map
Engineered Performance
1784 Corn Rd. Suite D
Smyrna, GA 770-434-0051
Show Map
Star Dyno
6850 Buford Hwy
Doraville, GA 770-416-9691
Show Map
Active Autowerkes
9940 SW 168th Terrace
Miami, FL 33157
(305) 233-9300
All Pro Dyno
3460 Kennel Club Road
Yulee, FL 32907
(904) 261-6255
MD-800-I Portable
Aerocomp Racing
4205 St. John's Parkway
Sanford, FL 32771
(407) 330-7300
MD-AWD-IMP-DE-GB
Baugh Alignment
1912 West Jordan
Pensacola, FL 32501
(850) 433-5555
Speedo Tester
Beachside Automotive
108 Tomahawk Dr.
Indian Harbor Beach, FL 32937
(321) 773-7379
MD-250
Breathless Performance Products
2024-B Tigertail Blvd. Blg. 7,
Dania, FL 33004
(954) 925-7725
MD-250-P
ABC Dyno of North GA., Inc.
1046 Parkway Court Suite C
Buford, GA 30518
(770) 831-7401
MD-250-P
Augusta Transmission Clinic
1853 Gordon Highway
Augusta, GA 30904
(706) 738-7812
MD-250
CK Performance
988 Laing Cross Rd.
Dawson, GA 39842
(229) 894-1532
MD-250
Four Blakeny Auto
4584 Robinson Road
Valvosta, GA 31605
(229) 244-4578
MD-250
J.A. Echols & Assoc.
3395 Fox Street
Suite 103-C
Duluth, GA 30096
(770) 232-5304
MD-ASM
MV Performance
533 Commercial Dr.
Statham, GA 30666
(770) 725-7862
MD-1750
Spin Peformance
3266 North Lizella Rd.
(478) 447-0700
MD-250
The adjsutable fuel pressure regulator method is almost worthless unless you have a way to measure either EGT or AFR in order to adjust in the proper direction. Your "nose" is not a good air fuel ratio meter. A tell-tale sign that you've done it wrong will be indicated by broken parts and/or blown motor. So either way, you'll end up spending money. May as well do it right the first time. There's lots of lucky folks out there that were able to throw it on and go. There are more who threw it on and broke.
Daggar do you think i need to get one and have somebody who can messure my AFR set it for me or just lesve it alone? and do i necessarily need to go through getting my timing/ MAF-injectors matched/ AFR set and computer set to match all of the above. my loong run goal is 500 hp so am i gonna have to go through all this again if get a stroker motor and better heads and more boost?
I'm with Daggar on this one:
75mm TB
75mm MAF (possibly 80mm PMAS or Pro-M)
42lb injectors-face it, it's better to have and not need, than need and not have.
255 in tank pump
GOOD TUNE!
If you want to add the fuel rails, Mallory makes a pretty nice kit, but it requires custom (AN style) fuel lines. Aeromotive's is pricey, but more than you'll ever need for fuel rails, and it plays well with the factory fuel system. Haven't looked at Professional Products, but I know it's only $200 with all required parts...or you could assemble your own from a rail kit, and some fabbed hoses and such.
