injectors
gwiesem said:
do i need new injectors and maf,i have a stock bottom end with ported e7 heads,comp cams 218 222 duration,512 lift 1.6 roller rockes and cobra intake.
As the others have said, the injectors should be good for now.
You may see some power from swapping to a 94-95 Mustang MAF/MAS though.
It is important to get the correct MAF combo though.
You would need a 70mm MAF with a F2FV MAS/sensor mounted on it.
this will work perfectly with stock 19Lb injectors.
No other Ford MAF/MAS combo will work though!!!
jason
