need to replace an injector would a set of 39# be to much for a mach 1 with some bolt ons
ok, people sell used 03/04 cobra stock 39# pretty cheap thought it might be worth it and do you know a good fuel injector cleaner?
Use the formula for determining what size fuel injectors you need. Remember that fuel injection has to support all the power an engine makes, including the power lost due to friction.
(Fuel flow in LBM X Number of cylinders) / 0.5
If you are forced induction you would use 0.6 instead. By this formula, 24# injectors only support 384 flywheel HP. That's only 326HP at the wheels.
Depending on the mods you have, or the HP goal you envision, 24# injectors might not be enough. Breaking 326 RWHP in a four valve is not too hard at all. You probably can't do it with bolt ons, but it is easily achievable with cams, exhaust and intake. Heck, pick two of them and you could do it.
The formula was originally intended for 85% duty cycle and gross horsepower in naturally aspired conditions (cars used to be rated on gross horsepower way back in the day). When you get to talking about parasitic losses such as accessories or superchargers it gets a lot more complicated. Using for 100% duty with RWHP naturally aspired is mathematically pretty darn close....But there is an issue with 100% duty cycle.
A fuel injector running at 100% is always flowing fuel. The problem with running past 85% is that you will inject liquid fuel droplets straight into the cylinder. This seriously raises the risk of fuel detonation because you don't have a homogeneous mixture in the cylinder at the end of your compression stroke. Multi port fuel injection was designed to inject fuel onto the intake valve (hot metal) to assist in vaporizing the fuel while the remaining liquid would be uniformly swept into the chamber by incoming air and conventionally evaporated.
When you operate above 85%, even a competitive tune in naturally aspired form, to say nothing of forced induction, introduces the possibility of detonation.
When you get to a point where you are above 85% on your stock injectors, you will be needing a tune anyway. You might as well tune with bigger injectors to support future improvements. Also you will make more power through your proper fuel mixture by being able to run a more aggressive tune.
But like Dark04GT says, a mail order tune is not the way to do it. A major change in injector size necessitates a custom tune. Mail order could do it, but it would have to be real conservative to be considered reliable.
That's just my two cents.
