Inner Tie Rod Install
  • Thread starter Thread starter RUSH2112
  • Start date Start date Apr 6, 2005
R
RUSH2112
22
Pittsburgh, PA
Apr 6, 2005
  • Apr 6, 2005
Can anyone tell me how easy/hard it is to install a passenger inner tie rod?
I tried to get a wheel alignment and Sears said it had some 'play' and recommended a replacement. I can get a replacement, but Sears wants like $50 to install it.... Can this be easily done myslef???? If so, please provide brief, detailed instructions. Thank you...
ram360
2,162
Pennsylvania
Apr 6, 2005
  • Apr 6, 2005
Not hard at all. Basically pull your outer tie rod. You'll need a pickle fork to do that (even though I've seen people use a hammer) Once you do that unscrew the out tie rod. You'll need special tool (I forget then name of it (but it's designed to remove the inner tie rod It basically a 3ft long deep socket that slids over the inner tie rod so you can unscrew it from the rack using a 1/2 ratchet. Then just reverse the procedure. Even though $50 doesn't really seem to expensive and if you dont' have the tools and never done it before it might be worth it. Good luck
Mavrick
2,264
Collingwood, ON
Apr 6, 2005
  • Apr 6, 2005
If you can get the tool for $50 then i think it would be worth it to do it yourself.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 6, 2005
  • Apr 6, 2005
When I changed one, the main problem was the pop rivet in the inner tie rod end that kept it from unscrewing from the rack. I had to drill out the pop rivet and once I did that, I used 2 big adjustable wrenches to unscrew the inner tie rod end from the rack. The replacement tie rod end didn't need a pop rivet.
Wheels-Tires Front end shimmy on 79 foxbody
  • 79fox2245
  • Jul 4, 2025
Fox 5.0 Mustang Tech Jul 7, 2025
General karthief
Suspension Tire screeching after shorter endlinks and tie rod ends?
  • RotFox90
  • Apr 13, 2024
Fox 5.0 Mustang Tech Apr 14, 2024
RotFox90
  • dan50
  • Jul 18, 2026
dan50
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
J
Severe shaking/vibrations in steering wheel
  • jacket999
  • May 20, 2025
SN95 V6 Mustang Tech Jun 1, 2025
NtheGAME
N
