Innova scanner not working 88 5.0
I bought a scanner to diagnose my high and surging idle but when I plug my scanner in and press test when I have the key turned to on nothing happens but apparently the CEL is supposed to come on briefly when I turn on my car which it doesn’t along with all of the warning things as well do not come on any insight would be great
1988 Speed Density cars do not have a CEL. You can certainly add one if you want, but it will not prevent you from using the Innova. 1988 Cali MA air cars do have the CEL
I assume you have the Innova 3145? If so, follow these directions. Make sure you have a battery in the tester, as it's commonly assumed it is powered by the vehicle. You do need a 9V in there
View: https://youtu.be/Hwtm6avQMPc?si=j5UKD-Rp5KxfOEG5
  • Useful
Reactions: Mcmahst
