  • SN95 4.6L Mustang Tech
Inside Dome Light Question
  • Thread starter Thread starter NPIGT
  • Start date Start date Dec 8, 2004
N
NPIGT
96
  • Dec 8, 2004
ok guys, well I went to get into my car and I shut the door. I started the car and the dome light turned on and will not go off. I disconnected the battery and checked my car alarm and neither worked. So right now I have the fuse pulled for it, but I need to know if anyone else has had this problem. Maybe possible causes(short somewhere) and solutions.... Its a 1998 GT. And if anyone has the wiring for it. I would greatly appreciate it (alot). Thanks in advance for your help!
Green Flea
28
California
Dec 8, 2004
  • Dec 8, 2004
Twist ur headlight knob to turn it off.
karuso99GT
136
St. Louis, Mo
Dec 8, 2004
  • Dec 8, 2004
I had the same problem with my 99. My solution was to remove the dome bulb and not worry about it.
CRZYHRSGT
240
5.7 miles north of THE Ohio State University
Dec 8, 2004
  • Dec 8, 2004
Yea, first check the headlight ****ch. Also, there's a big thing with Tauruses. The door switch for the dome light when the door is open is in the door latch on the door. Get some good spray penetrant/lube and soak the living crap out of that thing and then open/shut the door a few times to work it in.
My dad had the same problem once with his '98 Taurus, and after this fix it never came back.
GT-03
630
  • Dec 9, 2004
Does the light never go off? Have you tried to let it go for, let's say, an hour?
The reason I ask, is to see if the entry system computer is still working. If it is, then eventually the light will time out, and the computer will turn it off.
M
mrpositraction
296
Columbia, MO
Dec 9, 2004
  • Dec 9, 2004
WD-40 the latch. I have a 98 SHO and the light stayed on. I pulled the relay for about 1/2 a year and then read somewhere how to fix it. It fixed it and the light never stays on anymore. Also learned to use my parking bread at least once a week to keep the rear brakes firm
GOLDENPONY
1,503
LOVELAND, OHIO
Dec 9, 2004
  • Dec 9, 2004
Dome Light
Problem: Pin Switches. Get to from inside the door. Major Ford PITA.
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
W
Interior and Upholstery New Member auto dimming mirror install issue
  • WigSnatcher92
  • Aug 25, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 28, 2025
Mustang5L5
  • Gulftown980x
  • Jul 29, 2026
squeak93
A
95 GT parking brake instrument cluster light trouble
  • Aroenias
  • Jun 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 24, 2025
Mustang5L5
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
