Install price estimates? Details inside.
GRGT1994
1,034
What do you guys think would be a reasonable install quote for the following combo?
I am looking at the Trick Flow top end kit (street heat). With that, I would do LT headers, mid pipe (already have cat back), upgraded fuel pump, fuel pressure regulator, injectors, MAF, throttle body.
So what do you think it would cost to get all that done by a good/trustworthy shop?
I am kinda debating doing the install myself. But if I can get someone else to do it for a reasonable price . . .
I'd say at least $1000 for labor if their doing the fuel pump too oh and if you plan on deleting the egr have fun finding a shop that will do it plus there is a lot of stuff you have to plug up (if deleting egr) and finding the right bolts will be a pain. Plus there is other parts you will have to buy like a 3/8 spacer to clear the valve cover if your going to run a 94-95 style throttle body because the elbow you need (which also doesnt come in the kit) hangs down where you bolt the egr crap in at. Also you will need some kind of oil fill kit and I dont recomend the one trick flow sells because the cap is a pain in the @$$ to get off especially if you don't get enough oil on the o-ring. Oh and I would recommend replacing the cam lock plate bolts (mine snapped of when I was taking them out).
If you have the time do it yourself and use that money you were going to spend on the install and buy something else for the car.
