  • SN95 4.6L Mustang Tech
install
  • Thread starter Thread starter 03silverstang
  • Start date Start date Jun 12, 2005
03silverstang
123
  • Jun 12, 2005
Hey everyone. I am probably going to buy an MRT catted H pipe. I have flows welded in to the stock CB, how is the installation? are there any special tools you need or is it just a basic bolt on? any problems or fitment issues? Will I notice a lot of a difference or just a little difference in the sound? any power improvements?
Thank you all
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
Jun 12, 2005
  • Jun 12, 2005
It should bolt right up easily. Only simple hand tools required. You will notice a gain because the stock mid-pipe is so restrictive, BUT since you just went with weld-in mufflers im assuming you still have 2.25" piping on your CB. So when you put that 2.5" mid-pipe on you are going to create a bottle-neck effect. You would notice more or a gain if you went with 2.5" piping all around. You will notice a pretty good difference in sound though
03silverstang
123
  • Jun 12, 2005
Does there have to be another part to connect the 2.5 mid pipe the the stock 2.25 CB? how does that work. Also I was thinking about maybe getting the SLP LM instead of the H pipe. What would sound better the mrt pipe and the weld ins or the stock H pipe and SLP LM catback?
Thanks
Give Me TP
936
Republic of Texas
Jun 12, 2005
  • Jun 12, 2005
The SLP Loudmouth and MRT catted H-pipe sound and perform great together.
03silverstang
123
  • Jun 12, 2005
But if I had to go with one for now what would you recommend?
Fox Removing smog only questions
  • 91GTstroked
  • Sep 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
91GTstroked
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
Engine Cleaning Intake valves with lower intake off
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 11, 2026
limp
  • Gulftown980x
  • Jul 29, 2026
squeak93
