  • SN95 4.6L Mustang Tech
Installed O/R X now idle issues?
  • Thread starter Thread starter 1987stangman
  • Start date Start date Jul 11, 2009
1987stangman
684
24
  • Jul 11, 2009
Since I am new to the 4.6L, I am sure it has some similar issues as the the 5.0 did/does. I installed a o/r X pipe today and the car idles great in P or N put when it it shifted to D or R the car dies unless I give it gas while shifting in to gear in which case letting of the gas the car will idle but LOW. No issues when driving though. Does the TB have a idle stop screw like the Fox 5.0?
Also, I know alot of folks complain about the check engine light comming on and have to use MIL's but my light has not come on yet but I plant to get a tuner soon anyway.
squeak93
2,342
414
164
Joplin, Missouri
Jul 13, 2009
  • Jul 13, 2009
Did you replace the passenger side gasket with a new OEM ford one? Most of the aftermarket ones will leak or if you didn't replace it at all, it will never seal up right. That will cause an exhaust leak and screw with the idle.
If the car idled fine before the mid pipe swap, don't touch the t/b adjustment screw as you will only be covering up another issue. Check your exhuast and get back with us.
You will need to get mil's/tune if you don't want the check engine light staring you in the face. A tune is the only way to FOR SURE not have a cel. I have mils and my damn cel stares me in the face everytime I drive.
1987stangman
684
24
  • Jul 14, 2009
No leak, I bought a new gasket from Ford and used some Permatex gold copper spray and after I tighend the bolts down I used my air impact on it so it's good.
Idle has worked itself out. I forgot to mention that I had the battery unhooked for the whole day so my guess is the computer just need some time to adjust. CEL still has not come on or even flashed.
Also, how does your Flowmaster sound with the H you have?
squeak93
2,342
414
164
Joplin, Missouri
Jul 14, 2009
  • Jul 14, 2009
Glad the idle fixed itself.
The flows are ok with an o/r H. Not too loud but sound decent when you punch it. The don't crackle too bad like most other cat backs (non chambered mufflers). Just don't run them with an x pipe unless you want a very tingy sound.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jul 14, 2009
  • Jul 14, 2009
yeah it might have taken a bit to relearn idle but If possible check your long and short term trims with a scan tool to see if you have a vac leak or something.
BTW never mess with the TB stop
1987stangman
684
24
  • Jul 15, 2009
Yep, I did not heed the warnings from other posters and stuck a O/R X on there with my Flows. Sounds OK but, lets face it, not as good. So now I need to find a compatible set of Mufflers..
Twista
510
@ the z00 in chicago
Jul 16, 2009
  • Jul 16, 2009
sound clips please
isjoining
143
Orlando, FL
Jul 17, 2009
  • Jul 17, 2009
MAC mufflers would sound good with an o/r x
  • Gulftown980x
  • Jul 29, 2026
squeak93
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
