  • 1994 - 1995 Specific Tech
Installed Summit Radiotor!
  • Thread starter Thread starter Guero
  • Start date Start date Apr 22, 2007
1 of 2 Next Last
Guero
2,148
Apr 22, 2007
  • Apr 22, 2007
Was pretty easy to install!!! It was worth buying the universal. It was really easy to work with. I had to move the Fan a little over to the drivers side. I had to buy a resevoir tank cuz the factory one didn't fit. It was 8 bucks. Other than that it was pretty straight forward. I haven't ran it cuz Im missing a hose to connect to the resevoir. Ill post pics up when I get some. It was like 169 bucks. I also installed a shift light, and a NGK wideband
chaos254
467
NJ
Apr 23, 2007
  • Apr 23, 2007
i installed the same radiator a long time ago...definitely worth the money! How come u couldn't get the stock overflow to fit? Mine is on there with no problems.
Guero
2,148
Apr 23, 2007
  • Apr 23, 2007
Cuz the radiotor is really thick... the fan barely fit
badstang123
397
Santa Clarita, CA
Apr 23, 2007
  • Apr 23, 2007
My Fluidyne made things a lot tighter too. It made me nervous at first but I've never had any problems.
1TallMF
955
Montreal
Apr 23, 2007
  • Apr 23, 2007
Sounds good man, I'll deffinetly look into those if and when I need a new one
Pokageek
2,767
MA, USA
Apr 23, 2007
  • Apr 23, 2007
Thanks to me. :SNSign:
Guero
2,148
Apr 23, 2007
  • Apr 23, 2007
Were you the one who posted it?? If so thanks I was about to go fluydine!!!
Blackened302
1,439
South TX
Apr 23, 2007
  • Apr 23, 2007
sweet! this is on my "get asap" list! big ups to Keith for posting the link!!
oh yeah... POST PICS!!!!!
95Vert
1,785
North Mexico (deep south Texas)
Apr 23, 2007
  • Apr 23, 2007
Post pics guero! How did you hold it down?
Guero
2,148
Apr 23, 2007
#10
  • Apr 23, 2007
  • #10
Well I took out the rubber pieces on thebottomandthebracketthatholds the resevoir down. Drilled to holes 1 on each side, put up a L braket on each hole. That held the radiotor from falling. And on the top, ok let me explain the best I can. I fit it under were the top of the bracket is for the resevoir bottle. On the the top part was like a extra pice of metal from the body. I twisted it up and just screwed it to the radiotor. Ill post pics. I suck at explaining
Pokageek
2,767
MA, USA
Apr 23, 2007
#11
  • Apr 23, 2007
  • #11
Pics. And Yes I was the one. But I refuse to take any responsibility if it doesn't go right!
95Vert
1,785
Apr 23, 2007
#12
  • Apr 23, 2007
  • #12
Yes you do!
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Apr 23, 2007
#13
  • Apr 23, 2007
  • #13
summit radiator is definatly a nice piece
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Apr 23, 2007
#14
  • Apr 23, 2007
  • #14
Im thinking about getting one of these. With it getting hot around here I need to find some way to keep my car under 210*
The Green GT
1,269
Louisiana
Apr 23, 2007
#15
  • Apr 23, 2007
  • #15
Which one did you get?
http://store.summitracing.com/egnsearch.asp?N=700+4294839040+400304+4294810996+115+4294891681
Pokageek
2,767
MA, USA
Apr 23, 2007
#16
  • Apr 23, 2007
  • #16
chaos254
467
NJ
Apr 23, 2007
#17
  • Apr 23, 2007
  • #17
heres a quick writeup I did when I installed mine a couple of years ago:
"The size I got was the 28x19 but I dont see any reason why the 31x19 wouldn't fit. Taking out the radiator/fan/overflow was pretty simple. I made sure I cleaned the overflow real good because there was probably like 2" of sludge built up in the bottom of it! I also flushed the system before I put everything back together just in case. You only need a 1/8" pipe fititng for the overflow(costs about .59 cents.)The radiator fits in with no problems but like Slyvette posted you only use the top driver side bracket to hold it. You reverse the rubber grommet in the bracket and there is a hole on the driver side bottom near the radiator where it'll fit in with a longer bolt/nut. It was pretty stable with that but I put a metal bracket on top for some cheap insurance. Mounting the fan was probably the hardest part. I wanted it to mount flush with the radiator because otherwise the fan housing would be really close to the pulleys. Nothing the old sawzall wouldn't fix Just trimmed down each side a little bit and it fits pretty good. I used 2 heavy duty wire ties to hold the fan. The overflow went on the same way with really no modification. Since the radiator sits further out you just need a long bolt with a nut to hold the overflow to the bracket, or you can use a wire tie"
i'll try to snap some quick pics tonight when I have to put my bumper back on...
T
tjh566
608
Northern Va
Apr 23, 2007
#18
  • Apr 23, 2007
  • #18
what about this one, direct replacement, over an inch thicker than stock (2" thick) and build "looks" good:
http://cgi.ebay.com/ebaymotors/Mish...ryZ33602QQihZ013QQitemZ230118770131QQtcZphoto
95Vert
1,785
Apr 23, 2007
#19
  • Apr 23, 2007
  • #19
tjh, for that price, I'd rather stick to the Summit. I've never really heard of those radiators and they're coming off of ebay.....
Guero
2,148
Apr 23, 2007
#20
  • Apr 23, 2007
  • #20
Well the radiotor seems pretty good. I was beating on it with the A/C and it never passed 180. But its still not that hot over in Phoenix
1 of 2 Next Last
Question about power steering.
  • 2003 mustang gt modded
  • Oct 23, 2024
1994 - 1995 Specific Tech Nov 15, 2024
manicmechanic007
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
M
  • mnky99
  • Sep 5, 2025
mnky99
M
