I installed the Accu-Fab plenum and 75mm TB, The kit came from RPM outlet and it included a 85mm MAF housing. They told me to reuse the stock sensor in their housing.
My problem is the car is not idiling very rough. Could my TPS need adjusting?
What should the voltage be on the TPS at WOT?
Any help would be great.
, or you could have a vaccum leak somewhere. Double check ALL your hoses and connections to ensure you didnt miss anything. Id bet its a vaccum leak somewhere, but if thats not the case its more than likely your IAC which is around a $60 part. Do you have a "hanging" or "stuck" idle, or is it just jumping everywhere?
