Installed Tranny and Intake, NOW CAR WONT IDLE CORRECTLY! WTF? HELP!
FiveOhhStang
299
Sanger, Cali.
Alright, I took off my upper intake since my buddy is porting me and intake, and I figured it would be done by the completion of my transmission swap, it wasnt so I put it back on. Now my car wont idle right, and it shakes....
What could be the problem? Other than possibly a vacumm problem, could it be a bad transmission/clutch install? I installed a 94 cobra tranny, a Flywheel, Spec Stage II Clutch, and Had to install a newer 94 Mustang GT Starter....what could be other problems I should look for? Maybe a low battery? :shrug:
What year is your car? I only ask because you cannot bolt in an SN95 tranny into a fox. Imput shaft is too long. The vibration is somewhere in your drivetrain, obviously, possibly the driveshaft. Did you line up the flywheel correctly? it only goes on one way... so itd be tough. But people have forced the bolts into make it line up.
