  • 1994 - 1995 Specific Tech
installing a AFR gauge some help please??!!
  • Thread starter Thread starter fish254
  • Start date Start date Oct 2, 2006
F
fish254
237
Brooklyn NY
Oct 2, 2006
  • Oct 2, 2006
i just want to know what wire to tape here is the diagram for wiring
javascriptop("0900823d801ddb57","gif_large","no")
F
fish254
237
Brooklyn NY
Oct 2, 2006
  • Oct 2, 2006
http://www.autozone.com/images/cds/gif/large/0900823d801ddb57.gif
thats the link
HISSIN50
34
129
Oct 2, 2006
  • Oct 2, 2006
In that diagram, it looks to be red/blk (left) and grey/lt blue (right).
Good luck.
F
fish254
237
Brooklyn NY
Oct 3, 2006
  • Oct 3, 2006
is that inside the car where it plugs into the pcm??
F
fish254
237
Brooklyn NY
Oct 3, 2006
  • Oct 3, 2006
i really want to wire it from inside the car it will make it so easy any one
HISSIN50
34
129
Oct 3, 2006
  • Oct 3, 2006
It will be the same color wires as I recall. Look at Pins 43 and 44 (left/right, respectively).
Good luck.
95cobraguy
637
11
Concord, NC by way of LI, NY
Oct 3, 2006
  • Oct 3, 2006
just run the wire from the gauge to the proper pin at the computer, i remeber it being the gray wire with blue stripe. i used a scotchlock connector to make the connection. your going to have separate the wires a bit to make a solid connection as the wires are wound up tight at the computer connector.
HISSIN50
34
129
Oct 4, 2006
  • Oct 4, 2006
And/or run a wire from both pins (left and right O2's) to a SPDT switch so you can toggle from bank to bank.
Good luck.
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
L
2000 Mustang PATS - Broken Key and Wire - HELP!
  • Laree Taylor
  • May 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
manicmechanic007
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
