installing a AFR gauge some help please??!!
It will be the same color wires as I recall. Look at Pins 43 and 44 (left/right, respectively).
Good luck.
fish254 said:
i really want to wire it from inside the car it will make it so easy any one
just run the wire from the gauge to the proper pin at the computer, i remeber it being the gray wire with blue stripe. i used a scotchlock connector to make the connection. your going to have separate the wires a bit to make a solid connection as the wires are wound up tight at the computer connector.
And/or run a wire from both pins (left and right O2's) to a SPDT switch so you can toggle from bank to bank.
Good luck.
