  • 1994 - 1995 Specific Tech
installing a/c compressor?
  • Thread starter Thread starter NotQuik
  • Start date Start date Jul 1, 2005
NotQuik
5,158
29
88
Central Florida
Jul 1, 2005
  • Jul 1, 2005
Mine went bad and I was just wondering how difficult it would to to install a new one with it being under the power steering pump and also my manifold line is leaking as well (line with the high and low pressure valves) is that difficult to intall as well? thank
94opalgt
358
AKRON,OHIO
Jul 1, 2005
  • Jul 1, 2005
1 bolt to unhook the lines from the compressor.4 bolts to take it off,2 on top two on bottom,actually they are all on the side.jack the car up and you can get all out from under the car.i just took all my a/c stuff off.as for the lines,just get an a/c line removal tool,you can get them at any auto part store
T
tjh566
608
Northern Va
Jul 1, 2005
  • Jul 1, 2005
but once you replace it you will have to evacuate the system and recharge it which takes some knowledge of refrideration and special tools and equipment.
NotQuik
5,158
29
88
Central Florida
Jul 3, 2005
  • Jul 3, 2005
thanks guys, i just want to install the compressor myself and the lines...I have a buddy that can ecacuate the system and recharge it for me at the ford dealer ship.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jul 3, 2005
  • Jul 3, 2005
Simple swap, had mine done in under an hour. If you already leaked out your refrigerant, you won't need it evacuated before removing the old one, but you'll need to run a vacuum pump on it for a good hour after installing the new one before charging it, to remove any non-condensables from the system (air, moisture, etc.). Also, I believe the correct oil to use is PAG 150. Just pour it directly into the compressor before you install it, and you're all set.
NotQuik
5,158
29
88
Central Florida
Jul 4, 2005
  • Jul 4, 2005
that was my next question, how much oil do i add in there and do I need to add it before installing the compressor?
WHITE94COBRA
816
HUNTINGTON BEACH
Jul 4, 2005
  • Jul 4, 2005
While your doing it get a new expansion valve, like 5 dollars, I did the new compressor, new dryer, new lines, new oil, and new refrigerant, all to find out my damn valve was bad! 5 min fix and $35 to have it done...... God damn car.
NotQuik
5,158
29
88
Central Florida
Jul 5, 2005
  • Jul 5, 2005
what exactly is the expansion valve? Also how difficult is an evaporator to install as well, just curious on that one.
Power steering hoses
  • Teen'93stang5.0
  • Apr 3, 2026
1974 - 1978 Mustang II Talk & Tech Apr 14, 2026
Teen'93stang5.0
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
1965 Mustang with 80s 5.0 engine in it Power Steering hose or connection ID?
  • spearce
  • May 19, 2026
Classic Mustang Specific Tech Jun 8, 2026
AeroCoupe
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
T
A/C Compressor Reliability with Supercharger Setup – Need Advice
  • ThotTrap
  • Aug 29, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 29, 2025
