k-man New Member Jul 27, 2009 7 0 0 spokane, wa Aug 2, 2009 #1 Aug 2, 2009 #1 has anyone installed a f303 ford racing cam in a auto car? or was thinking a trick flow stage 1 cam.
Dan95-5.0 Active Member Jun 14, 2003 1,110 0 36 Manitoba, Canada Aug 5, 2009 #2 Aug 5, 2009 #2 i got the 2031 crane cam in mine
I inphiniti Active Member Mar 15, 2003 412 3 28 Providence, RI Aug 5, 2009 #3 Aug 5, 2009 #3 yeah im running a anderson b31 cam in mine. idles very pretty! my suggestion with a cam on an auto would DEFINITELY get a stall converter.
Black95GTS Active Member Jan 8, 2004 1,644 3 38 Marlborough, MA Aug 5, 2009 #4 Aug 5, 2009 #4 k-man said: has anyone installed a f303 ford racing cam in a auto car? or was thinking a trick flow stage 1 cam. Click to expand... The best cam for stock heads is the stock cam. Gears, stall, tune, sub-frames, short throw shifter, intake..... Adam
revhead347 Apparently my ex-husband made that mistake. 20+ Year Stangneter Jun 14, 2004 9,296 1,640 214 Acworth, GA Aug 6, 2009 #5 Aug 6, 2009 #5 Black95GTS said: The best cam for stock heads is the stock cam. Gears, stall, tune, sub-frames, short throw shifter, intake..... Adam Click to expand... Ditto. What kind of heads are you running? If you have some ported stock heads you can install a Trick Flow cam with the stock converter no problem. Kurt
N -Nick- New Member Aug 6, 2009 25 0 0 Aug 6, 2009 #6 Aug 6, 2009 #6 both of those cams suck... whats are your mods? custom cams are the only way to go....
