  • 1994 - 1995 Specific Tech
Installing Bumpsteer Kit
  • Thread starter Thread starter 91LX_5L
  • Start date Start date Jul 12, 2005
91LX_5L
1,943
British Columbia
Jul 12, 2005
  • Jul 12, 2005
Is it hard? Whats invloved? Anyone have a link or pics of the install or finished product?
Thanks
LoudToy958
435
Bremerton, WA
Jul 12, 2005
  • Jul 12, 2005
Thanks
Its pretty easy actually. Pull the tire, pop the tierod off the spindle, measure it really good, then remove it, and install the new parts using the same measurements. You should get an alignment soon after. That will ensure everything is properly aligned.
Hardest part is to put the spacers on while your car is on a flat surface. The weight has to be on the suspension. Then just change the spacers till the body of the rods is level with the a-arm. Your steering wheel will be 10X more responsive to minor adjustments............
PICS - I love a chance to whore pics of my ride.....
BEFORE INSTALL
AFTER INSTALL - Not level with a-arm yet
AFTER INSTALL - Level with A-Arm
LoudToy958
435
Bremerton, WA
Jul 12, 2005
  • Jul 12, 2005
Oh yeah, I forgot to tell you, you will probably have to cut the bottom half of your dust shields off your spindle. Sucks, but not hard to do.
91LX_5L
1,943
British Columbia
Jul 13, 2005
  • Jul 13, 2005
Humm I didnt think it was that invloved. I read the MM install guide and seems like it takes a while. Im not even sure if I will get bumpsteer or not, mabye ill pass on it. Did you notice a big diffrence? What is bumpsteer exactlly how would I feel it, pulling on the road right, on bumpy roads?
thanks man
LoudToy958
435
Bremerton, WA
Jul 13, 2005
  • Jul 13, 2005
thanks man
Its a little involved. Not hard though. I did notice a huge difference in steering. It is not really needed unless you have excessive bumpsteer. When your car follows the bumps in the road, thats when you have the problem. You would know if that was happening. Your steering wheel would turn in odd directions over bumps.
I didn't need it, but I did need new tie rod ends, and I got a great deal on the kit when I bought my X2s, so why not..............
D
Dave14
193
Calgary, Canada
Jul 13, 2005
  • Jul 13, 2005
Does the bumpsteer kit include the tie rod ends?
Thanks.
LoudToy958
435
Bremerton, WA
Jul 13, 2005
  • Jul 13, 2005
Thanks.
It replaces the tie rod ends. It is just a set of highly adjustable tie rod ends basically. The kit lets you reset the geometry of you steering after a significant front suspension drop. That keeps the bumps in the road from controlling your vehicle.........
D
Tkx installation problem
  • dropteeth
  • Aug 21, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 10, 2026
limp
Mustang I I truck gasket
  • roadsterII
  • Aug 4, 2026
1974 - 1978 Mustang II Talk & Tech Aug 8, 2026
Enzio
J&M Products Launches New Knuckle to Toe Link Bearing Kits for 2015+ Ford Mustang IRS
  • MRaburn
  • Mar 6, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Mar 6, 2026
MRaburn
D
08 Turbo kit. Who made this???
  • Don7Up
  • Oct 3, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 10, 2026
highplace11
H
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
