Suspension Maximum Motorsports Tapered Bumpsteer Kit MMTR-2 - Replacement Spherical Rod Ends
AeroCoupe
6,181
4,275
183
Claremore, OK
I needed a set of spherical rod ends for my old bumpsteer kit and needless to say they are not cheap. Noodled around found that the threads are 5/8-18 LH on the MM aluminum tube and the spherical rod end has the same threads with a 5/8" ID where the bumpsteer stud goes (tapered or through bolt style). QA1 makes really nice pieces so if anyone needs one I would go that route. Grainger sells them so if you have one local to you they are pretty reasonably priced.
Anyhow, just thought I would share in case anyone else was needing replacements.
  • Useful
Reactions: General karthief
