  • SN95 4.6L Mustang Tech
Installing engine with AT still in car?
  • Thread starter Thread starter keithnra
  • Start date Start date Dec 29, 2010
keithnra
53
  • Dec 29, 2010
Its been a while since i installed a AT in a car so i need to refresh myself. I am putting the motor in my recently acquired 96GT, my ? is do i need to bolt the Torque conv. to the flywheel and just try and walk the engine in place or do i need to put tc on the tranny and then drop engine in and bolt the tc to the flywheel. Its just been a while and i wanted to ask before i start.thanks keith
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Dec 29, 2010
  • Dec 29, 2010
It's vital that the torque converter be fully seated on the transmission. There should be two clicks as the TC seats.
Rotate the motor and transmission only in the forward direction. NEVER turn the TC backwards. It will disengage from the input shaft and bad things will happen.
Pre-rotate the TC converter bolt holes to line up the with inspection/access holes. Rotate the motor to match.
Turn the motor clock wise (CW) from the front crank shaft damper.
keithnra
53
  • Dec 29, 2010
ok so that answers my ? the tc needs to be on the tranny and then bolt the tc to the flywheel thru inspection whole thanks keith
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
