I am trying to install these Moroso Drag Springs and it has been such a nightmare. I am using a spring compressor which uses a rod that goes through the spring. I have to compress the spring way down until I get the spring in where the rod of the adjuster is going throught the hole in the controll arm, and then I jacked the controll arm until the car started to lift, then started uncompressing the spring but as the controll arm bagan moving down until it moves over and then gets in the way of the nut and it can't turn. The tool fell off and I bent the tool trying to get it out.
WHAT AM I TO DO!!!!
I am thinking of just giving up and doing Coil Overs, but I don't have the money.
WHAT AM I TO DO!!!!
. I think I will try to get ahold of a regular mcpherson spring tool that compresses from the outside. I saw one once that look as though it would work. There has to be another way.
