installing lower control arms, need torque specs
  • Thread starter Thread starter breadfan35
  • Start date Start date Aug 22, 2004
breadfan35
45
Dallas,Tx
Aug 22, 2004
  • Aug 22, 2004
installing lower control arms, need torque specs. Pls help me figure out the torque specs to adjust to when mounting.
Bottom Line; What is the torque specs needed for this project?
Thanks
HISSIN50
34
129
Aug 22, 2004
  • Aug 22, 2004
your repair manual will list all the specs. good luck.
TT91
1,536
Paramus, NJ
Aug 22, 2004
  • Aug 22, 2004
Use german torque specs, GOODENTIGHT...
all seriousness, nice and tight will be fine, its not a very critical thing to worry about
HISSIN50
34
129
Aug 22, 2004
  • Aug 22, 2004
i sorta agree but i would not feel good about that, especially telling someone i dont know to do it (he may not have the 'feel' for torque values that you or someone else does).
we dont even know if he is working on the front or rear suspension, do we?
i like knowing the torque specs, cuz even if i do not use a torque wrench, i know how much to reef on stuff. i.e. i will take it easy on 100 ft/lbs, but if something calls for 180, i can really go to town. you dont want a suspension bolt coming loose - especially since the front LCA bolts are not captured (no cotter pin or castle nut).
Sirsure, im not in disagreement with you - just not something i would let a stranger do ( i have some weak friends whom think that 50 ft/lbs is a ton of torque) - that is where im coming from.
good luck.
10HoleLX
257
Southern California
Aug 22, 2004
  • Aug 22, 2004
The only part of a car that I use proper torque is on the heads and intake manifolds.
Everwhere else simply by feel, just like how sirsureshot39 said.
The bigger the bolt and the finer the threads, the more torque they can take!
fox racer
577
Staten Island, NYC
Aug 22, 2004
  • Aug 22, 2004
agreed.i only figure to torque the bolts in critical areas... as mentioned above like heads intake, clutch and engine parts.
one mor ething, when you torque down control arms, make sure the weight of the car is on the part of the suspension, like in normal operating way. if you tighten them down qith the suspension extented, the bushings will squeak and it wont feel right
PNY PWR
522
Wichita, KS
Aug 22, 2004
  • Aug 22, 2004
looks like on the rear lowers, chassis 80-105/axle 70-100....uppers, chassis 80-105/axle 70-100
front control arms, 110-150
breadfan35
45
Dallas,Tx
Aug 22, 2004
  • Aug 22, 2004
Thanks for the info so far and let me clarify. I am putting on HPM Mega Bite Jr. Lower control arms and was just wonder if there were certain torque specs I need to use when Installing the control arm back to the diff and to the body of the car. Thanks for all the info again.
Electrical Lincoln Mark VIII Replacement Fan Motor
  • AeroCoupe
  • Sep 26, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
AeroCoupe
R
Suspension Lower control arms needed
  • racer_dave
  • Feb 9, 2026
1974 - 1978 Mustang II Talk & Tech Feb 20, 2026
C
Suspension Rear suspension help
  • Clark302
  • Aug 17, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
Clark302
C
Tightening upper control arm bushings at ride height dilemma… need some help
  • AnthonyA1234
  • Dec 27, 2024
  • 2 3
6K
Fox 5.0 Mustang Tech Feb 27, 2025
General karthief
Fox In search of a Spec clutch dimension.
  • PonyGTrider
  • Jun 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 3, 2025
PonyGTrider
