Installing lowering springs
  • Thread starter Thread starter Morales
  • Start date Start date Dec 18, 2005
M
Morales
136
Miami, FL
Dec 18, 2005
  • Dec 18, 2005
Hi all! do i need any special tools when installing springs on my 92 Coupe?
Im also installing new KYB struts upfront and shocks out back!
Numbles
998
Chicago, IL
Dec 18, 2005
  • Dec 18, 2005
http://www.stangnet.com/tech/spring.html
M
Morales
136
Miami, FL
Dec 18, 2005
  • Dec 18, 2005
im guessing it's the same thing on a fox body
Numbles
998
Chicago, IL
Dec 18, 2005
  • Dec 18, 2005
Yes.
Anthony85stang
43
Meriden, CT
Dec 18, 2005
  • Dec 18, 2005
The rear springs arent too bad but id get my hands on a spring compressor to do the fronts they have some pressure behind them.
a_k
170
Saratoga NY
Dec 19, 2005
  • Dec 19, 2005
yeah get a spring compressor, it will make things easier, I've taken my springs out twice in the front without one it can be done but they do have alot of pressure and it's a pain in the ass
bcd
274
arab al
Dec 19, 2005
  • Dec 19, 2005
if the springs are short enough you can do it with a jack
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Dec 19, 2005
  • Dec 19, 2005
The springs in the back aren't the problem... It's the ones up front that are a pain in the @$$.
Also, it's worth mentioning that you should get some C/C plates and Offset rack bushings to realign the front tire geometry and the tie rod ends.
M
Morales
136
Miami, FL
Dec 19, 2005
  • Dec 19, 2005
here's a dumb question for you guys.
When I bought the car the guy threw in a set of BBK lowering springs. 2 are short the other two are fairly tall. Which go uo front and which go out back? I'm guessing the shorter ones go up front and the taller ones out back.l
W
wazazzle
618
In the dumpster behind McDonalds. WA
Dec 19, 2005
#10
  • Dec 19, 2005
  • #10
you're correct..... taller in rear, shorter in front. there should also be a stamp such as 4444.44r or 4444.44f..... the r stands for rear, f stands for front.
MrKwik
1,008
Kansas City, Kansas
Dec 19, 2005
#11
  • Dec 19, 2005
  • #11
The fronts will also have more coils and are the same diameter top to bottom. The rears have the pigtailed last coil.
I have never had to use a compressor for fixed rate springs. I have used "C" springs, Steedas, MAC's, Jamex etc. Variable rate will require a compressor and are quite a bit more of a pain to install. I can install a set of fixed rate springs in about an hour and a half. The Eibach pro-kit springs in my 90 took me the better part of a day trying to get the compressor to cooperate. Rears never take more than about 15-20 minutes and wont require a compressor but a prybar is sometimes handy.
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
3K
Fox 5.0 Mustang Tech Apr 11, 2026
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
H
New here and thanks
  • HoosierD420
  • Aug 30, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 30, 2026
HoosierD420
H
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
