installing roller rockers
  • Thread starter Thread starter cwdunnet
  • Start date Start date Apr 3, 2006
C
cwdunnet
30
toronto
Apr 3, 2006
  • Apr 3, 2006
is there a certain way you need to install roller rockers on the heads, i want to upgrade to 1.7 roller rockers and i want to know if i can just bolt them on or do i have to sequence them or what? please let me know thanks.
midlife89
91
youngstown,oh
Apr 3, 2006
  • Apr 3, 2006
Go to www.cranecams.com,they have instructions there.If your looking for a set used a friend at work is upgrading to TF heads with stud rockers.He'd probably give you a good deal.Let me know.
ExplodingGopher
517
The mistake on the lake (Ohio)
Apr 3, 2006
  • Apr 3, 2006
if they are stud mounted you have to set the lash. Just twist the pushrod between your fingers as you tighten the rocker down, as soon as you feel some resistence in twisting the pushrod, you are at 0 lash, tighten down 1/4 to 1/2 turn more and lock the rocker down. Of course this has to be done in a certain sequence to make sure you are on the flat part of the cam lobe for that rocker, im not familiar with the 302 sequence, but that is the way to "adjust" them.
If its pedestal mounted, then im not sure because i have studs.
midlife89
91
youngstown,oh
Apr 3, 2006
  • Apr 3, 2006
I thought gt 40 heads were pedistal mount unless you had them drilled or used the conversion kit.
ExplodingGopher
517
Apr 3, 2006
  • Apr 3, 2006
Thats true, im just explaining studs because thats what i have. Pedestals IDK, i think you just bolt down and go, but shims come into play there.
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
G
Sup. Just got back into the game with a 1986 4-eye vert.
  • GeorgeG
  • Nov 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 7, 2026
limp
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
