Installing Steeda Tri-Ax Short Throw Shifter
It's as basic a job as there is. Unscrew the shift knob, remove the shifter plate, remove the cover underneath it, unscrew four bolts, pop off the shifter, drop the new one in, tighten up the four bolts, adjust the stops as per the instructions, reinstall the cover and the shifter plate and install your knob. Even if you're a complete newbie with a wrench, you should be able to do it in well under an hour. I've done a few and it takes me about 15 minutes.
The only possible issue is getting the shifter off the transmission once the bolts are removed. The shifter is stuck on there pretty good sometimes. If it won't come off easily, put the knob back on the shifter handle and rock the shifter firmly from side to side. That should break the shifter loose from the tranny.
