  • 1994 - 1995 Specific Tech
Installing tach, quick wiring questions
  • Thread starter Thread starter 91LX_5L
  • Start date Start date May 5, 2005
91LX_5L
1,943
British Columbia
May 5, 2005
  • May 5, 2005
I got my manual its a autometer lunar.
Anyways it says to hook up the green wire to the COIL or ELECTRONIC IGNITION. Dont wanna sound like a dumbass but where do I hook this up? Pics would help but dont worry if u dont have one.
Also it says to hook up the RED to the ignition switch, where can I find this?
Last but not least
White to 12V dash lighting wheres the easiest source for this?
It also says to hook up the negative to a good ground, shows a pic of the battery - that is not nesscary is it? Couldnt I just find a nice spot of metal behind my dash somewhere, scrape off the paint and ground it there?
THANKS!!
HISSIN50
34
129
May 5, 2005
  • May 5, 2005
if you have a stock ignition, the tach wire can go to the neg side of the coil.
for 12 volts, you can pretty much source any key-on 12 volt source that is close to your guage. i do grounds the same way. i find a nice clean one (ohm it out to be sure - tachs are finicky) and use it.
for the dimmer, you can grab the dimmer wire at the back of the headlight switch or tap into a wire that dims (at the radio, HVAC, dash clock, ashtray light, etc).
good luck.
Q
qwick94GT
108
  • May 5, 2005
Splice it into the negitive coil wire. Right were it plugs up. Thats what I did.
91LX_5L
1,943
British Columbia
May 5, 2005
  • May 5, 2005
ok well I guess ill use my cd deck for 12V, and use my AC contols etc for the dimmer. For ground should I tap into my cd deck ground or just make a new fresh one? Either way doesnt bother me.
What do you mean ohm out the ground?
Where is my coil located? I never knew it had a + and a - I thought my plug wire just pluged right on to it...im confuised now? Ignition coil? or what coil? Anyone got a pic of this?
Black70Fastback
319
Dyer, IN
May 5, 2005
  • May 5, 2005
well it would be the part that your main "plug" wire goes to from the dist. but right next the heavy spark wire, is a lighter pair of wires coming from the engine harness. ones marked + the -, i dont remember if you have to unplug it to see which is which.
91LX_5L
1,943
British Columbia
May 5, 2005
  • May 5, 2005
ahhh ok there is a little harness on the back wich looks like it feeds into a resistor or somthing like that...that must be the one?
91LX_5L
1,943
British Columbia
May 12, 2005
  • May 12, 2005
anyone?
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
W
Interior and Upholstery New Member auto dimming mirror install issue
  • WigSnatcher92
  • Aug 25, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 28, 2025
Mustang5L5
P
Electrical 2001 GT Overcharging
  • PseudoGT
  • Dec 3, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 13, 2025
65 Mustang: Tried to install a tachometer from Oreilly's with no success.
  • spearce
  • Mar 26, 2025
1965 - 1973 Classic Mustangs -General/Talk- May 19, 2026
spearce
P
Electrical MSD box wiring for an 88 GT- few questions.
  • pindude80
  • Jul 20, 2024
Fox 5.0 Mustang Tech Jul 25, 2024
pindude80
P
