Installing Tailpipe problem
  • Thread starter Thread starter savegoodautonfg
  • Start date Start date Feb 27, 2007
savegoodautonfg
1,085
  • Feb 27, 2007
hey guys,
my question is I am trying to connect two pipes that are both 2" OD.
What do i need to do to make them connect to eachother. They are the same size so they wont connect.
I hope you understand what im trying to say.
Thanks.
TomCat
412
Utah
Feb 27, 2007
  • Feb 27, 2007
You can rent a pipe expander from CSK or Autozone. I know we had one when I worked there... then just slip it in and clamp.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Feb 27, 2007
  • Feb 27, 2007
My first question would be why are you installing 2 inch tail pipes? Seems like you arechoking the system off. Unless you are a closet Tuner? And this is on your civic.
onefstsnake
792
Northern VA
Feb 27, 2007
  • Feb 27, 2007
you didnt buy the Summit catback did you?
T
TheUser
1,859
Springfield, MO
Feb 27, 2007
  • Feb 27, 2007
1) As suggested above, rent a pipe expander and expand the pipe and use exhaust clamps
2) Use a 2" diameter band clamp. It's basically a metal band that wraps around both pieces and has two bolts that clamp it shut. It's about $10 and may have to be specially ordered. Summit carries them as does some auto parts stores. I got one at O'Reilly.
3) Take it to an exhaust shop and have it welded. This method provides the most leak-free assurance, but it's obviously welded, so it would have to be cut to remove the exhaust if you so desire.
savegoodautonfg
1,085
  • Feb 27, 2007
Its on my dad's ford ranger 1997 not for my mustang.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Feb 27, 2007
  • Feb 27, 2007
Glad you cleared that up I was starting to wonder about you. I like the weld method specially if they are stainless so you can take em off and use it on another vehicle down the road. Or re use it when the rest of the tail pipe rusts out.
U2SLO450
118
  • Feb 27, 2007
Take it to any exhaust shop. They will flange it out so it will fit. It wont cost much at all, maybe like 40-50 bucks.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Feb 27, 2007
  • Feb 27, 2007
maby like $10 bucks...it's a 2 min job....inluuding setting up the bender/expander. We have guys come in all the time and ask for something expanded or shrunk down.....or bent. Hell we have guys bend 1/2" copper piping and want us to make a complete exhaust system using the 1/2" pipe as a template
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Electrical 88 EEC Injectors batch firing ?
  • Dustin 86GT
  • Dec 8, 2025
Fox 5.0 Mustang Tech Jan 8, 2026
gkomo
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
J
Power Wire Upgrade Question
  • jhaling
  • Dec 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
