Installing Upper/Lower Control Arms
I just did mine last weekend. I had the axle out for a rebuild and ring gear install. I used a floor jack, milk crates, and jack stands. I was able to push the axle in place on the milk crates. Then I placed it on the jack stands. I hooked up the lowers first. You'll be able to roll the axle fowards later for aligning the upper arms bolt holes. I used to different size punches to align the holes.
And definitely don't torque down the nuts until the car is on the ground or cinderblocks and fully loaded. It will help if you have someone assisting you. You'll appreciate the extra muscle needed to wrestle it in!
strokedandblown said:
Once your done your gonna feel good about your self, till you drive it, then you might not feel so good if something's wrong
Then you fix it and feel good again...until something else is wrong.:crazy: You speak the truth, stroked. Like anything you love to do--it drives you nuts sometimes!
