Instrument Cluster Fox ?
  • Thread starter Thread starter 88mustang_5.0sb
  • Start date Start date Sep 22, 2004
88mustang_5.0sb
40
Solvang, CA
Sep 22, 2004
  • Sep 22, 2004
I have an 88 5.0 with the 80mph speedo. Is the 140mph cluster from the 91-93 or so Fox a direct swap? Is it easier to swap the whole cluster or just the display panel? Who would sell the cluster along with cable and tranny gear and for how much $?
jb89coupe
416
CT
Sep 22, 2004
  • Sep 22, 2004
The 87-89 clusters are different than the 90-93's. The wiring was changed because of the airbags. You'll need a 140mph cluster or speedo from an earlier year. The "display panel" is the cluster. Maybe you're talking about the whole dash surround too? All you really need is the speedometer, but it's easier to just pop a whole cluster in. You don't need the surround.
You can find a used one on eBay pretty easy, just make sure it's pre-1990. They go for ~$50-$100 usually. Not sure why you'd need a cable or a drive gear for it, the speedometer itself is what's calibrated.
giddyup306
3,041
Sep 22, 2004
  • Sep 22, 2004
They are also a different shape.
V
v8only
2,378
22
49
Sep 22, 2004
  • Sep 22, 2004
Yes, but from what I understand, they'll fit with some modifications. "what" these mods are, I'm not sure...perhaps pulling the speedo part out and putting it on your speedo, but it'll work, you'll have to search for the answer if someone doesn't chime in.
88mustang_5.0sb
40
Solvang, CA
Sep 22, 2004
  • Sep 22, 2004
So the wiring and shape of the cluster is different pre-90. Hmm... So is there such a thing as an OEM 140mph guage that will fit in my 88? If the calibration is in the speedo then you're right I wouldn't need to change out the tranny gear. I do need a cable but only cause mine's broke.
V
v8only
2,378
22
49
Sep 22, 2004
  • Sep 22, 2004
ssp mustangs (police mustangs) had oem 140 "certified calibration" speedometers.
additionally, I'm pretty sure some factory 140mph speedo's made their way through too.
jb89coupe
416
CT
Sep 22, 2004
  • Sep 22, 2004
Factory 140mph clusters from 89 show up frequently on ebay ($50-100), just do a search. The 89 police models (like mine) came with a 160mph "certified" speedo, some 88 and 87 cruisers came with the 140mph, all are pretty rare to come accross and expensive when you do.
trbkrb
1,976
Houston, TX
Sep 23, 2004
  • Sep 23, 2004
Also Ford Motorsports sold a replacement 140 & 160 MPH gauge for the 87-88 models. It was a $100 part, and still commands that much used.
The 90+ clusters have an arch cut out of the bottom above the steering wheel, while the 87-89 ones are straight across at the bottom, just so you can tell them apart if you are looking for a complete cluster.
Do a search and you will find a lot of threads on the subject, but here is the info from one I posted:
There are 5 ways to convert, depending on how much you want to spend and how much work you want to do and what look you want.
1) 89 140 speedo (edit: and Ford Motorsports 140) is easiest and probably most expensive. (supply & demand!) Drops right in, no other changes needed.
2) Send your 85 speedo to Brothers Performance and have it calibrated with new white face gauges. http://www.brothersperformance.com/...g/bbkcal1w.html
3) Get a 90-93 speedo and remove the speedo from the case. Remove the mechanism from the speedo face and put the 85 face on the 140 mechanism. Replace the 85 glue on face with a new 140 face, either stock 89 or white face gauges. There are several threads with more details on Stangnet about this.
4) use the complete 90-93 speedo, but you have to cut and file and drill the plastic face to fit the 87-89 cluster properly. The turn signal arrows are different, and the texture on the face is slightly different. This is what I did, but I got a 92 cluster for $20!
5) use the 90-93 cluster, but rewire the connectors so the gauges will work. Ford changed the wiring of the cluster when they added the airbag, so it is not a direct swap. Here is the wiring diagram showing the differences: http://statefilingsoftware.com/pict...luster87-93.pdf
Good luck!
E
Drivetrain Odometer quit working
  • El Dee
  • Feb 6, 2025
Fox 5.0 Mustang Tech Feb 7, 2025
85GTStangGuy
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
M
Progress Thread mkk50's Progress Thread
  • mkk50
  • Aug 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
