Intake/Carb Suggestions
  • Thread starter Thread starter 85foxman
  • Start date Start date Jan 22, 2013
85foxman
51
Southwest Wisconsin
Jan 22, 2013
  • Jan 22, 2013
I just got done rebuilding my engine recently...306 with the e303 cam and stock 1985 heads...I got the Edelbrock 7121 Performer RPM intake and ordered the 1405 Carb...my question is do I have to use the manual choke Carb or can I use the 1406? Are the 1405 or 1406 carbs bolt on ready? I did some searching and found some useful info but thought I would get some "expert" suggestions because this is my first build and wanna do it right the first time...I am saving for a nice set of heads and I know the stock heads are killing me but they will have to do for now...thanks for any and all info.
7991LXnSHO
wanna catch the space herp
7,387
2,746
194
Kearney, NE
Jan 23, 2013
  • Jan 23, 2013
Good intake and the cam will be a higher RPM one too.
I used a Holley vac. secondary carb w/electric choke on my other stang the first time. Yes, the stock heads will hurt performance, but it still will beat some vette powered Camaros and be fun if you have a manual or a loose convertor. If not, you Will want some low end back. Use Rhodes lifters and have a wider torque band. I did not have noise and had lots of vac. with them. 25 mpg highway too.
85foxman
51
Southwest Wisconsin
Jan 23, 2013
  • Jan 23, 2013
I ended up going with the 1405 carb...my car is a 5 speed trans...will I need to do anything or get anything else for this Carb to work on my 85 stang?
7991LXnSHO
7,387
2,746
194
Kearney, NE
Jan 24, 2013
  • Jan 24, 2013
I saw you had a manual, but added the convertor comment for other 4 eyed owners.
The carb looks like a manual choke, right? So that cable will need run. I also doubt the fuel line will just line up. I got a dual snorkle air cleaner and the cold air intake parts off of an 83 to 85 GT (probably the same year as yours) and it worked great. The single snorkle breather choked it.
Unless you have solenoids hooked up to a computer on the stock carb, I do not see there being big problems using the Edelb. carb.
7991LXnSHO
7,387
2,746
194
Kearney, NE
Jan 24, 2013
  • Jan 24, 2013
I'd still want an electric choke. I'd be surprised if you can not add it later like Holley lets you. The Edel. design should allow for good secondary opening adjustment to kill bog off the line and still have good acceleration. You can fine tune the mixture later, but it should be close enough for jazz out of the box and 600 cfm is a good size for a hopped up 302.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jan 24, 2013
  • Jan 24, 2013
Did you have any work done to those heads? Did you install a good set of pistons with valve relief's in them? If so get rid of those E5 heads. Stock E7 heads off a 87-93 mustang are better then those E5's. There are a lot of bargins to be found on heads that will make you so much happier then the E5's will.
7991LXnSHO
7,387
2,746
194
Kearney, NE
Jan 24, 2013
  • Jan 24, 2013
My second build of the carburated 1979 302 was caused by a spun bearing. At least I was told so, it may have been an oil pump shaft. But it ruined the cam bearing surfaces and more. I went with a stock Marshall rebuilt E7 motor, (I was starting a new job and
HAD to have a car), with stock E7 heads. The stock cam and newer heads equaled out the zip of the old set up with 79 heads and an E cam.
BUT compared to the 79, my 1991's seriously ported E7 heads really haul hatch with an E cam and EFI. Porting has made a world of difference in E7 heads. And GT 40s are still supposed to be better.
I am also saving for real performance heads and Rhodes lifters to tame the cam at low RPM and scream up high. Yes, I want it all.
85foxman
51
Southwest Wisconsin
Jan 26, 2013
  • Jan 26, 2013
Question...do I need to use an adapter to hook up my throttle bracket and since I have a 5speed trans do I need the throttle adapter that bolts to the throttle arm on the Carb itself?
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
Engine Edelbrock 1406 install help
  • scottcarp10
  • Dec 11, 2025
Fox 5.0 Mustang Tech Dec 15, 2025
scottcarp10
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
