Intake gasket failure?
84Gt350
298
Kirkland, WA
Hello to all here. I just picked up a 96 3.8 with water in the oil, I just did a compression check and all 6 are above 160lbs so I am guessing it's the intake gasket leaking. Is this a common failure? Anything special I should look for or any helpful hints for taking it apart?
Thanks,
Dan
Dan,
I highly doubt it is the intake and it is more likely the head gaskets. Do not run it with coolant in the oil. It will destroy the bearings. Get that shiit out of there fast.
Check the coolant overflow bottle for bubbles if the engine is running or the smell of exhaust. You will also see carbon in the coolant which looks like pepper in the coolant.
If you look at the spark plugs, the offending cylinder will have the spark plug looking like new as the steam cleans all the fouling off. If you have none of those symptoms, it could be the intake.
