Intake gasket ??
  • Thread starter Thread starter Mopar1
  • Start date Start date Jan 9, 2007
M
Mopar1
61
Shelton, WA
Jan 9, 2007
  • Jan 9, 2007
Brain farting here..
I'm helping a buddy replace the lower intake gasket on his cobra intake. The gaskets he got were composition types from napa. There is nothing on the gaskets that say which side goes toward the head. The flat side?? or the side with the ridges?
Also should sealer be used around the water ports? Is that applied to the head or gasket?
Thanks
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jan 9, 2007
  • Jan 9, 2007
the Napa gaskets you are talking about probly have a graphite on both sides right....it dosn't really matter with those but I would put the side with the sharper edge down.....but that's jusm me but with those gaskets it don't mater.
TheBocSez
652
Converse, TX
Jan 9, 2007
  • Jan 9, 2007
When I used those gaskets, I was told by the NAPA guy that the ridge goes towards the head.
I used a thin coat of sealer on both sides of the gasket at the water port. No leaks to date.
M
Mopar1
61
Shelton, WA
Jan 10, 2007
  • Jan 10, 2007
Thanks guys.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 10, 2007
  • Jan 10, 2007
My favorite trick that saves time and effort is the stay in place gasket. Be sure that you scrape (don't use a wire brush) all the old gasket material off, then clean all the surfaces with acetone or MEK.
When the surfaces are clean, use weather strip adhesive on the head to manifold surface, and on the side of the gasket that mates to the head. Follow the instructions on the tube or can and when it gets tacky, press the gasket down on the head.
Clean the area where the rubber rails mount to the block in front and in the rear with more acetone or MEK and do the same trick with the weather strip adhesive that you did to the heads.
Coat the rubber seals and the gasket area around the water passages with lots of Blue Silicone gasket sealer and put it together. Yea! no leaks, and no gaskets that shifted out of place.
If you reuse the injectors from your old setup, a repair kit is available from most auto parts stores if needed. Coat the injector body "O" rings with oil before you use them and everything will slide back together. Take the other advice you got here and run with it.
Fuel injector seal kits with 2 O rings and a pintle cap (Borg-Warner P/N 274081) are available at Pep Boys auto parts. Cost is about $2.74 per kit. The following are listed at the Borg-Warner site ( http://www.borg-warner.com ) as being resellers of Borg-Warner parts:
http://www.partsplus.com/ or http://www.autovalue.com/ or http://www.pepboys.com/ or http://www.federatedautoparts.com/
Most of the links above have store locators for find a store in your area.
Use motor oil on the O rings when you re-assemble them & everything will slide into place. The gasoline will wash away any excess oil that gets in the wrong places and it will burn up in the combustion chamber.
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
Engine Head gasket port matching plus head/intake port alignment
  • PonyGTrider
  • Dec 10, 2024
Fox 5.0 Mustang Tech Dec 12, 2024
PonyGTrider
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
What's it Worth? 2000 GT
  • Mustang5L5
  • May 8, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jun 13, 2026
KRUISR
L
Engine Need help diagnosing 2 dead cylinders
  • lvgnmz
  • Feb 13, 2025
Fox 5.0 Mustang Tech Feb 13, 2025
Mustang5L5
