Hi guys, ran into a problem with my intake. I have the lower installed and torqued down, but on the upper there is on the provision for the vaccuum line and for what I assume to be the fpr. What do I do with the other vacuum lines. One runs off of a black vaccuum tree labeled "s" for the slot it goes into. The other one runs from the little tree with thin black and white lines where the egr vacuum goes, and another into the charcoal canister. There is an extra provision for another vaccum line or something right after the egr spacer on the intake. Also, the hose that runs from the bottom of the intake to the vaccuum tree for the pcv, no clue where to connect it either. Totally stumped guys. What do you guys think? I really, really want this car running before saturday so I can run it and see what it does. Thanks.
Intake is a Edelbrock RPM if it helps.
