  • 1994 - 1995 Specific Tech
Intake Manifold questions
  • Thread starter Thread starter Synned
  • Start date Start date Feb 24, 2007
Synned
took tubgirl on a date and got banned
Mar 31, 2005
991
Philly
Feb 24, 2007
  • Feb 24, 2007
Sorry this has been answered before guys...
I am about to buy a gt40 intake manifold, probably an explorer.
Most of the ones I see on ebay say up to '93 because of the boss for ACT and internal EGR.
What would I do with both of these things? Plug the ACT hole and EGR passages?
Thanks
Joe
JJ95GTID
1,141
Phoenix, AZ
Feb 24, 2007
  • Feb 24, 2007
You would need to plug the ACT hole in the #5 runner in the lower intake if there is one. The EGR hole in the lower doesn't need to be plugged because the upper intake will cover it if there is one.
The reason I am saying "if there is one" is because the Explorer's used an external EGR setup similar to our 94-95 mustangs. I doubt those holes are drilled and tapped on Explorer intakes. Mine aren't and that is because I have the later model intake with the airgap in the upper intake between the two sets of staggered port holes.
I am pretty sure the earlier model Explorer intakes weren't tapped and drilled to save time and money on the assembly line.
Synned
Mar 31, 2005
991
Philly
Feb 24, 2007
  • Feb 24, 2007
This is the one I was looking at getting:
That looks like it has the EGR passages, BTW the lower I have is this:
Which does have the exhaust port as well.
So with this combo, all I would have to do is plug the ACT hole with a bolt?
Thanks
Joe
JJ95GTID
1,141
Phoenix, AZ
Feb 24, 2007
  • Feb 24, 2007
That bottom picture shows clearly that there is no hole for the ACT. Look at the #5 runner...see that circle just to the right of it. That is where the ACT would go on a Fox style lower intake.
I have a red X for the second picture.
The first picture shows the EGR hole just below the TB opening. If you use an elbow adaptor it will block off that hole which is what you want it to do.
On the 94-95 the EGR gasses go right into the TB opening through the side of the elbow adaptor.
Synned
Mar 31, 2005
991
Philly
Feb 24, 2007
  • Feb 24, 2007
This isn't a boss for the act?
Thanks
Joe
JJ95GTID
1,141
Phoenix, AZ
Feb 25, 2007
  • Feb 25, 2007
The hole right below the #5 is for the fuel injector. Notice in the picture that the #6 has the same hole. All the intake ports will have an injector hole. The hole on the bottom or your picture is for your coolant temp gauge (instrument panel gauge) sending unit. If you look on your stock lower intake you will see what I mean.
Also, the upper intake has way more vacuum ports than you need on the Mustang. You can either block them off or loop hoses from one port to another.
Synned
Mar 31, 2005
991
Philly
Feb 25, 2007
  • Feb 25, 2007
Thanks, you've been very helpful.
One question I can think of for now, do I reuse my stock bolts?
I'm sure there will be more to come
Joe
T
tjh566
608
Northern Va
Feb 25, 2007
  • Feb 25, 2007
I did.
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
Engine Explorer - Lower intake internal cleaning
  • R82148V
  • Nov 11, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Dec 6, 2025
rednotch
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
