intake manifold spacer
By increasing the runner length you will increase low end power but suffer on the high end. If you have an auto go for it. I have a heat spacer on my standard trans car but that is only for valve cover clearance.
It is used primarily to create valve cover clearance. The extra runner length may affect power/torque curves - a bit more torque at lower rpm; a bit less power at peak -- but nothing significant. If you're iceing intake components at the strip between rounds, it may let you cool the upper down a bit more effectively. But as a practical matter - if you need more clearance, use the spacer. If you're looking for more performance, spend your money elsewhere.
jaidedeye said:
i also am putting a 1 inch spacer on my car.....do you think a 1 inch will make a difference?
I wouldn't use a 1". I used one on a previous combonation and it KILLED the top end power of my edelbrock performer intake. It was on for about an hour and off it came and on went a 3/8". Just enough to clear everything I needed too, and BTW the 3/8 IMO didn't add any gains that you could honestly say could be felt. I agree with Michael Yount, unless it's for clearance, I'd spend money elsewhere.
I suppose I should add, I use a 1" on mine for clearance between the valve cover and the throttle body linkage. I have no egr spacer, and when I moved the throttle body that much closer to the intake, the bottom of it hit my Cobra valve covers. The spacer resolved that - and based on some temp. data I took when building my cold air box and relocating my ACT sensor, I don't think it made any difference on intake air temps - other than perhaps keeping them a bit lower for a bit longer - til the upper heat sinks along with everything else in the compartment.
