Intake misc hose?
  • Thread starter Thread starter chr1s11575stang
  • Start date Start date Nov 2, 2007
chr1s11575stang
64
Orlando, Fl
Nov 2, 2007
  • Nov 2, 2007
There is a hose coming from under the intake it looks to be about 3/8 maybe a bit bigger. But it sits right above the fuel rail and comes out towards the distributor. where is that hose supposed to go? The guy I bought the car from has it blocked off so i wasnt sure if it was supposed to connect to something.
backfocus
254
Little Rock, AR
Nov 2, 2007
  • Nov 2, 2007
Sounds like you are talking about the hose that goes to the charcoal canister ( Black box looking thing by the passengers side frame rail. If it is you should be able to trace it fairly easily and yes you should have it hooked up.
The Canister takes fuel fumes and recirculates them back into the motor. There should be a fitting on the bottom of the intake the hose attaches to. I have a GT40 intake and it is right above the drives side valve cover. I think it is in the same location on a stock intake.
Some people have removed the canisters and that maybe why it is not connected.
chr1s11575stang
64
Orlando, Fl
Nov 2, 2007
  • Nov 2, 2007
yeah the canister is still hooked up but theres only one hose hooked to it looks like it goes to the gas tank. but i will hook this one up. What is the purpose of the canister does it help the car run better?
backfocus
254
Little Rock, AR
Nov 2, 2007
  • Nov 2, 2007
It is more of a safety devise than anything else the way I understand it. I have heard that when it is not hooked up that people can smell the gas fumes more.
Here is my understanding of how it works. The canister takes excess fumes from the tank and they are absorbed into the charcoal. Once the engine is running those fumes get drawn from the canister into the engine and burn up.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 2, 2007
  • Nov 2, 2007
Yeah, I believe it is for emissions and safety...
On the Performer intake, the hose to the charcoal canister was under the upper on the passenger side of the intake.
chr1s11575stang
64
Orlando, Fl
Nov 2, 2007
  • Nov 2, 2007
ok so i fixed the hose but what is a shift solenoid? and where is located at
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 2, 2007
  • Nov 2, 2007
I typed in this thread by accident.
I hope you look up to see this
I did not want to post again...lol.
chr1s11575stang
64
Orlando, Fl
Nov 2, 2007
  • Nov 2, 2007
ahhhh ok.
PUNISHER RACING
1,124
FORD CITY, PA.
Nov 2, 2007
  • Nov 2, 2007
shift solenoid as in Power Stroke tranny's
chr1s11575stang
64
Orlando, Fl
Nov 2, 2007
#10
  • Nov 2, 2007
  • #10
Im not quite sure I got a code 92 and in the book it says shift solenoid. maybe i read it wrong or something
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 3, 2007
#11
  • Nov 3, 2007
  • #11
Code 42 & 92 (engine running) System rich - Fuel control or (memory) System was rich for 15 seconds or more (no HO2S switching) - Fuel control. Look for leaking injectors, fuel pressure too high, cylinder(s) not firing due to bad ignition.
Code 42 is the RH side sensor,
Code 92 is the LH side sensor.
Testing the O2 sensors
Measuring the O2 sensor voltage at the computer will give you a good idea of how well they are working. You'll have to pull the passenger side kick panel off to gain access to the computer connector. Remove the plastic wiring cover to get to the back side of the wiring. Use a safety pin or paper clip to probe the connections from the rear. The computer pins are 29 (LH O2 with a dark green/pink wire) and 43 (RH O2 with a dark blue/pink wire). Use the ground next to the computer to ground the voltmeter. The O2 sensor voltage should switch between .2-.9 volt at idle.
There is a fuse link for the O2 sensor heater power. According to Ranchero50, it is in the wiring near the passenger side hood hinge. Measuring the voltages will give a clue if it has shorted to the O2 sensor signal lead. The O2 sensor voltage should switch between .2-.9 volt at idle.
1965 Mustang with 80s 5.0 engine in it Power Steering hose or connection ID?
  • spearce
  • May 19, 2026
Classic Mustang Specific Tech Jun 8, 2026
AeroCoupe
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
Front window issues
  • bruno
  • Nov 7, 2026
Fox 5.0 Mustang Tech Yesterday at 10:26 PM
AeroCoupe
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
