Intake poping
  • Thread starter Thread starter LordMustangGT
  • Start date Start date Apr 3, 2007
LordMustangGT
118
Port Orchard, WA
Apr 3, 2007
  • Apr 3, 2007
after doing a E-303 cam swap on my friends car it does this intake poping at low RPM, but once you get on it it goes away and still has great power. any sugestions?
Matt
04MystiCobra
12
Corpus Christi, TX.
Apr 3, 2007
  • Apr 3, 2007
Is the upper intake getting hot?
LordMustangGT
118
Port Orchard, WA
Apr 3, 2007
  • Apr 3, 2007
not any hotter than normal I wouldn't think, but I'll dubble check,
Scooby5.0Doo
That's the fastest $400 car out there
Jan 9, 2003
833
beaverton
Apr 3, 2007
  • Apr 3, 2007
sounds kinda like intake backfireing. maybe the timing is to retarded or is that advanced i can never remeber which one. when you guys installed the cam did you degree it or just put the cam timing at 0
2004mysticobra
Lacey, WA
Apr 3, 2007
  • Apr 3, 2007
Sounds like lean opos but you're not running a blower.
If you feel that your intake is hot,moreso than normal, you may have a valve thats not seating all the way. May need shims for the rockers. Easy check if so.
Your timing is good right? If you're way out of timing your car will act like this as well.
fiveohwblow
Official Member
2,169
145
155
Apr 3, 2007
  • Apr 3, 2007
Did you use the stock cam gears and sprockets? also, what did you do for lining them up (as far as the notches go..)
WANNA_BE_GT
1,019
Seattle WA USA
Apr 3, 2007
  • Apr 3, 2007
Sounds like a timing issue to me.
LordMustangGT
118
Port Orchard, WA
Apr 4, 2007
  • Apr 4, 2007
It has brand new timming set. Nothing specail when installing, just lined up the two dots. Timming is only at 12deg. I'll dubble check that too. It made this hug backfire out the exhuast once trying to start it back up the first time, don't think it harm'd anything though. Sounded like a M100 going off. It was enough to losen the cat-back off a little. The only thing i could think was, some of the injectors got droped and had to use 3 used ones I had laying around. There white top, so I'm thinking there not the same lbs. They came out of a 86 5.0 non-HO t-bird. We're gonna buy a new set aways, that may be the problem right there.
WANNA_BE_GT
1,019
Seattle WA USA
Apr 4, 2007
  • Apr 4, 2007
I think the 85 non H.O. tbird used either 14lb or 17lb injectors. Not enough fuel definitely would cause issues and could be causing the computer to freak out... Sounds like quite the kanundrum you have....
fiveohwblow
Official Member
2,169
145
155
Apr 4, 2007
#10
  • Apr 4, 2007
  • #10
agreed. +1
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Apr 4, 2007
#11
  • Apr 4, 2007
  • #11
Moved to Tech.
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
