intake swap problems
  • Thread starter Thread starter tyler1986
  • Start date Start date Jan 11, 2010
T
tyler1986
tampa
Jan 11, 2010
  • Jan 11, 2010
so i did a gt40 intake swap on my 86 mercury capri. after i did the swap i started it up and it ran really rough. timmings good. smells likes its not burning all the fuel. i think i fouled out the plugs so now its not running. any suggestions?
G
greengoblin95
92
  • Jan 11, 2010
possibly a vacuum leak due to the gaskets being off. did you rtv the corners of the lower intake to ensure no gaps exist? also make sure your vacuum lines are all connected. if anything get come carb cleaner and spray your intake to see if it bogs down the motor. just spray the upper intake behind the throttle body and all the vacuum lines as well the lower intake of course.
stykthyn
5,232
2,652
223
gainesville
Jan 11, 2010
  • Jan 11, 2010
did you follow the proper torque pattern?
gungfusemaj
211
Bradenton Fl
Jan 11, 2010
  • Jan 11, 2010
It smells like fire, is your distributor clean and firing good on every wire all the way to the plug? Timing? Lean on the front back sides of the manifold, no I'm not on drugs, I just spent 2 weeks chasing down a idle issue when I first joined this site and after doing a swap out of upper and lower intake from stock to Trick flow I had an idle issue and when i was leaning over to grab a socket that I dropped back behind by the PCV Valve the engine changed idle back to normal and when I lean off it went high, Im telling you it was only 1 and a half turns on one bolt and that was all it was but this was the upper manifold bolt, the lower if not done in the right pattern in my experience/mistakes have left me loping and leaking from not using sealant on the front and back of the lnt manifold, just using the little gaskets with normal rtv , I know its not a gt 40 but no matter how sure you are about the bolts check all of them.
T
tyler1986
tampa
Jan 11, 2010
  • Jan 11, 2010
does anyone know if you can eliminate the the spacer between the throttle body and the upper intake?
ID89GT
1,659
18
49
Spokane Valley, WA
Jan 12, 2010
  • Jan 12, 2010
No, you need it to have the throttle cable bracket bolt to. Also it is what the EGR valve is bolted to. You can get a delete plate that will delete the egr function, and just have the spot for the throttle bracket.
apollo12
155
port st.lucie fla
Jan 12, 2010
  • Jan 12, 2010
Are you using the gt40 lower or the gt40p lower?
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
