Intakes
  • Thread starter Thread starter mustangderek22
  • Start date Start date Nov 16, 2005
M
mustangderek22
40
New Ringgold PA
Nov 16, 2005
  • Nov 16, 2005
I have a 89 lx 5.0. I`m looking into puttin a new and more powerful upper and lower intake on. Does anyone have any good ideas on what to use? I`m looking on something that will be good on the street. Thanks
Look Its Aaron
Your car looks like it came straight from Mexico.
2,634
Fontana, Cali
Nov 16, 2005
  • Nov 16, 2005
With stock heads you will yeild minimal results. Do you plan on changing out the heads later on?
I would say for a bolt on stang, go with a TMoss (www.tmossporting) ported lower intake.
If you do not choose that route, I would say a Cobra, Explorer or the Tubular Gt40 manifold.
M
mustangderek22
40
New Ringgold PA
Nov 16, 2005
  • Nov 16, 2005
yes i have stock heads, i wasen`t gonna replace them but if it`s gonna be ****ty result I will invest in some heads...ant suggestions on cheap good heads?
Look Its Aaron
2,634
Fontana, Cali
Nov 16, 2005
  • Nov 16, 2005
How much are you looking to spend? I would say for under $500, get some gt40/p heads.
M
mustangderek22
40
New Ringgold PA
Nov 16, 2005
  • Nov 16, 2005
ok thanks alot for your advice. I`m planning on doing all this intake stuff later this winter I want to do some gears first.
slow5poh
Senior Citizen
Jul 6, 2005
273
Citrus Heights, CA
Nov 16, 2005
  • Nov 16, 2005
If you need to pass emissions where you live I would opt for regular iron GT40's not the P's cause they don't have provisions for the thermactor smog tubes. If you don't have to pass emissions i agree with look it's aaron.
:SNSign:
KDK1988GT
1,937
Fredericton
Nov 16, 2005
  • Nov 16, 2005
I'm running a Holly System Max... with AFR 185's.....
Do you plan to go big anytime???
R
-=Red5.0GT=-
108
  • Nov 16, 2005
hit up ebay for some iron gt40's. you can get them for around 300.
soontobefastfox
275
Troy, Michigan
Nov 16, 2005
  • Nov 16, 2005
I wouldn't buy used heads espicially of ebay, you are bound to get ripped off.
I agree with the 2 above don't put an intake on stock heads you will lose power down low and gain it up top.
Do a h/c/i all at once to make give you the best gain.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Nov 16, 2005
#10
  • Nov 16, 2005
  • #10
I've purchased several items off Ebay, and have never been ripped off. Stick with a reputable person on there with a lot of good feedback, and you should be relatively safe. Going with something like a Cobra intake, you probably wouldn't lose any down low, but have an increase across the board. It would be pretty limited due to the stock heads, but definitely worth somewhere in the 20 HP range. As long as you avoid the higher RPM intakes like the Edelbrock RPM/Typhoon, you should see a fairly good increase, that would be noticable while driving.
304billet
315
#11
  • Nov 16, 2005
  • #11
I would do a set of AFR 165's, port matched Performer II and a Comp cam, Comp cam 1.6 roller rockers and Manley 4130 chromemoly pushrods. Call Comp cam for their rec's for a cam on ur combo w/ stock pistons.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Nov 16, 2005
#12
  • Nov 16, 2005
  • #12
Any plans to change heads in the next few years? Be realistic.
I
IntenseBlue
946
#13
  • Nov 16, 2005
  • #13
I'd get a TMOSS ported lower.
vristang
4,933
101
124
Seattle
Nov 16, 2005
#14
  • Nov 16, 2005
  • #14
mustangderek22
For a street car, stick with a long runner intake. I tried a short runner combo on my street 302 and it wasn't what I had hoped for. If planning for a stroker in the near future, then it would be more apporpriate. I like the cobra intake for cost/performance.
As far as ebay goes... As mentioned above research the seller as well as the part. You can find some decent deals. I got my ported trickflows for 700. I had them disassembled and cleaned at my favorite machine shop, and they were in perfect shape.
Consider what you might do in the future, while making your decision.
:Word:
M
mustangderek22
40
New Ringgold PA
Nov 17, 2005
#15
  • Nov 17, 2005
  • #15
thanks for all the help. I will be saving to purchase some heads along with my intake to get more performance. I will look on ebay my buddies go on their to get stang stuff all the time and they have no prob`s at all. thanks
C
crazyquik50
243
in the garage
Nov 17, 2005
#16
  • Nov 17, 2005
  • #16
reply
Never underestimate stock heads just throw on a set of 1.7 roller rockers and a cobra intake you will be happy with the result.
M
Electrical lights
  • Magnet86
  • Sep 11, 2026
Fox 5.0 Mustang Tech Sep 14, 2026
Magnet86
M
G
Engine ECU Question
  • GeorgeE
  • Oct 12, 2026
Fox 5.0 Mustang Tech Oct 19, 2026
JD1964
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
