- Mar 11, 2004
- 50
- 0
- 0
Can you use an intercooler on a non-supercharged motor and run the cold air right into the intake?
Michael Yount said:But if the gains were significant, you'd see somebody marketing a gadget to do it.
grrrrrrr said:I know on jet engines they sometimes spray a fine mist into the engines to lower the air temperature while it's sitting on the ground cause they tend to heat up. A fine mist should be able to lower the air temp entering your intake as well. That said I don't know what a fine mist would do to your internals or the electronics on the way down... Prolly rust your throttle body amoung other things...
I didn't suggest that they were the answers that anybody wanted to hear. And I certainly didn't mean to suggest that this is anything I would recommend for a N/A setup
SlowGT said:Here are some answers to your fine mist questions.
