Intercooler Pump Issues
  • Thread starter Thread starter Jon_Purdy
  • Start date Start date Apr 18, 2025
J
Jon_Purdy
  • Apr 18, 2025
Hello everyone.
Just completed the bench testing of my D.O.B Powa Pump. What is happening is very strange.
I took the battery out of the trunk. Put the power wire and the trigger wire on the positive post at the same time and the negative to the negative post. Pump runs. However, when I pull the trigger wire off the positive post (to simulate the key in the off position), the pump continues to run. Why? Also, if I put the positive wire and the trigger wire to positive post one after the other, pump will not run.
Hoping someone out there can help. I’m new to the electrical side of things.
Quote Quote
Report Edit
89ripper
925
309
103
Rockford, Illinois
Apr 22, 2025
  • Apr 22, 2025
Year and model of car? Heres a bump for you Jon
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
  • Mindseye007
  • Aug 16, 2026
Mindseye007
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
