Interior door panels
1. Remove the sail panel
If equipped, disconnect the exterior mirror control switch electrical connector.
2. Remove the interior door handle cover and the door trim panel bolt.
3.Disconnect the electrical connector and remove the window switch plate.
4. Remove the door trim panel center screw.
5. Remove the door trim panel handle cover and the door trim panel bolt.
6. Remove the 8 outer door trim panel screws and the door trim panel.
Disconnect the interior door handle actuating cable.
If equipped, disconnect the subwoofer electrical connector.
7. To install, reverse the removal procedure.
1 17D698 RH/ 17D699 LH Sail panel
2 21999 Door lock control knob bezel (RH/LH)
3 22620 RH/ 22621 LH Interior door handle cover
4 N807780 Door trim panel bolt
5 14527 RH/ 14528 LH Window control switch housing
6 — Window control switch electrical connector
7 W709996 Door trim panel screw
8 6320456 RH/ 6320457 LH Door trim panel handle cover
9 N807780 Door trim panel bolt
10 W709996 Door trim panel screw (8 required)
11 23942 RH/ 23943 LH Door trim panel
Nice post Bill!
I have a rattle inside my passenger side door, in your experience do you know what this could be? I would hate to have to take it to my dealer for this. I don't mind getting my hands dirty and taking the door panel off.
Some 2005-2008 Mustang vehicles built before 8/2/2007 may experience a buzz/rattle from the door panels when using the radio/CD player at elevated volumes or bass levels or voice broadcasts. This may be due to the window switch bezel vibrating against the door trim panel.
there is a TSB# 07-17-6 which deals with this problem.
Just did a search on this issue which brought me to this thread...
My '09 has major buzzing in the driver's door panel. I can't take it anymore. Do I just disassemble the panel and root around for what may be the problem? I've never done this work before and I don't know what to look for besides what was posted above. Sorry for such a rookie question...
