Interior Duplicolor Dye...
  • Thread starter Thread starter def1eppard
  • Start date Start date Aug 5, 2004
def1eppard
889
DFW, TX
Aug 5, 2004
  • Aug 5, 2004
I have an armrest that I sprayed with Duplicolor Interior dye and I was wondering am I supposed to spray clearcoat on it after? In all the threads I've seen about interior dye nobody ever mentions it.
def1eppard
889
DFW, TX
Aug 5, 2004
  • Aug 5, 2004
ttt
mustangmax
519
Glendale, AZ
Aug 5, 2004
  • Aug 5, 2004
No clear coat needed. It wouldnt allow enough flexibility on the soft vinyl and may crack. You just need to use some vinyl prep to get it clean, then spray it with the dye. 50 resto has two different dyes. One is for the soft vinyl and the other is for the hard plastic.
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Aug 6, 2004
  • Aug 6, 2004
if you want a kinda "wet" kind of look to it, yeah... it's always extra protection to the paint... one coat usually doesn't add alot of shine, especially on those kind of plastics
def1eppard
889
DFW, TX
Aug 6, 2004
  • Aug 6, 2004
Well I have already sprayed it. I did like some people said and cleaned it with soap and water real good first, I also used some armor all cleaner wipes, then went over the whole thing with alcohol. It may just have got a bunch of junk mixed in from outdoors, or maybe it's not dry all the way, but it just feels kinda "rough". It's not like you can see yourself in stock interior, but of course it will kinda have a semi-gloss. If you rub your hand on it you can tell by the way it feels it's been painted.
old_blue
1,783
282
124
Aug 6, 2004
  • Aug 6, 2004
is it still tacky? sticky when you touch it??
def1eppard
889
DFW, TX
Aug 6, 2004
  • Aug 6, 2004
Well it wasn't tacky last night, and it's not tacky today, it's just rough feeling. I think it may just have a bunch of trash in the paint. Somehow I knew this wouldn't work out for me.
artus70
72
  • Aug 6, 2004
New to the site, but figured I'd respond since I just did my enire interior from light grey to black and it looks and feels amazing, but I did have all these problems along the way. First off Armor All soaks into the plastic and will make it impossible to get it right even after cleaning it. Auto part stores have Plastic prep which actually turns the plastic or vinyl to a whiteish haze, you may have to do it a couple times to really get it clean but when its time to paint the first couple of coats actually soak into the plastic,After 2 or 3 coats let it dry for a few days and then hit it with a ton of armor all......it's soak that up too the first 3 or 4 times, use alot, and the shine and look is like the factory.
mustang90
1,209
15
58
Aug 6, 2004
  • Aug 6, 2004
maybe you got overspray on the panel? scuff it down and try it again. some of the dye's penetrate into the plastic though.
def1eppard
889
DFW, TX
Aug 6, 2004
#10
  • Aug 6, 2004
  • #10
Well I didn't use Armor All, I used Armor All BRAND cleaning wipes...they're just soapy wipes. I did scrub the crap out of it with dish detergent and water, and then rubbed on it with alcohol and it did kinda make the plastic part whitish on some parts like you said. The finish is very dull looking and the texture is kinda rough on both the plastic and vinyl top cover. So I should get some sandpaper to try and start over? BTW, the armrest is dark grey and i'm trying to make it more of a light grey.
mustang90
1,209
15
58
Aug 6, 2004
#11
  • Aug 6, 2004
  • #11
no, not sand paper! Go to your auto parts store and ask for a maroon color scoth brite pad. use a wax remover on the panels before scuffing. Then, scuff it down with that and then re-dye it. Should look factory!
WTB 89 Hatchback interior trim - any color
  • Zero_chance
  • Jun 14, 2026
  • Want to Buy
Want to Buy Jun 14, 2026
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
Paint and Body Dying interior quarter panels, can you color change?
  • AnthonyA1234
  • Aug 26, 2024
Fox 5.0 Mustang Tech Aug 28, 2024
limp
D
What's it Worth? 76 Cobra 2
  • dulcimerbob
  • Sep 8, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Sep 12, 2026
dulcimerbob
D
Electrical Defrost switch ignition?
  • Teen'93stang5.0
  • May 16, 2026
Fox 5.0 Mustang Tech Jun 3, 2026
Teen'93stang5.0
